I bought this a long time ago ... could it be used for what I would like to connect the box via the serial port and look at the boot box?
[HOW TO RECOVER] So you bricked your box
that's why I was looking. well thank you. only today I found this video where he writes how it can be used in my case https://youtu.be/-OtFvnZ24KU
Odoslané z MI 8 Pro pomocou Tapatalku
Dear all,
I have connected my H96 Pro Plus S912 with 3GB DDR3 and 32BG ROM, to the serial port, and I receive this info in loop,a nd the cycle ends at "DDR init failed..."
This mean that the DDR chip is burned???
Code:BL2 Built : 13:18:48, Dec 21 2016. gxl g4fc4d4e - xiaobo.gu@droid05 set vdd cpu_a to 1120 mv set vdd cpu_b to 1050 mv set vddee to 1000 mv Board ID = 1 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - FAIL DDR4 chl: Rank0+1 @ 792MHz - FAIL DDR init failed... Reset... GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY:0 ;EMMC:0;READ:0;0.0;CHK:0; TE: 54496
There are currently 3060 users online. 1 members and 3059 guests.
