Acemax IR Remote Control does not work. I solved this by recording the IR POWER command of MINIX IR Remote Control on my Fly Mouse Remote Control with the help of the IR EMITTER on my smartphone, and I can now turn on and off the Acemax M12N from my Fly Mouse Remote Control.
I do not know if the 100 Mbps ethernet connection works because I only use Wi-Fi at 5 GHz.
The RAM used after the update is between 50% and 85% depending on the number of applications started.
In summary, I am very happy.
