trying to get any KK rom to get working on original mk808b , no luck
    i have an original MK808B with 903 chip (checked on that inside)
    i tried every 903 kitkat rom , but always end up with 2 penguins
    there is only 1 kitkat rom that boots , and its an mtk version (lol) , obviously wifi and bt dont work (http://www.freaktab.com/showthread.p...(Fully-Working)
    I cant find what is different from the others (besides wifi chip) that makes it boot
    i was hoping someone already figured out what is the matter, because i see other people that have the same problem , but didnt find an solution
    Im running finless rom 2.1 at the moment but wifi keeps switching off and on randomly during an movie (wifi power saving off and full signal) and was hoping an kitkat rom would fix that issue
    also tried to get an usb wifi dongle to work instead , but none of the modules that supposed to work on my dongle work at all lol
    hope anyone has an idea , thanks
    Hi focussoft,
    look here :
    http://freaktab.com/forum/tv-player-...-fully-working
    http://vondroid.com/forums/mk808b-fi...-recovery.222/
    http://freaktab.com/forum/tv-player-...orking-wifi-bt
    for MK808B too,stands there,if possible try and flash it with KK kernel & recource of your Stock or any 808B Customrom.Always Backup your Data.Hope it helps.
    good luck
    gefattern
      Hi gefattern , thank you for your responce
      i dont know if u noticed , but your first link is the same as the one i posted , but its for a MTK type , i have a 903 type
      i also tried the kernel you linked to on all the kk rom's i tried ,with the same no-boot result
      on the vondroid website in your 3rd link i didnt find any kk roms
      i have been doing a lot of research on these forums , but so far did not find a solution
      i also tried the repacker app , and unpacked all roms i could find and compared them
      sadly my knowledge is not enough to figure out why the MTK rom boots and all 903 roms don't ,even though i 100% sure have a 903 chipset ,because i opened it up
      i hope anyone else can give me his 2 cents
        Hi focussoft,
        what about this
        TkiClean v1.2 - Android 4.2.2 Basis ist das Stockrom von Greekbuying, welches kaputnik33 gefunden hat und mir hat zu kommen lassen. Ich gehe mal davon aus das er dieses hier noch Posten wird. Änderungen gegenüber Original: -Sprache, Datum/Uhrzeit auf Deutsch/Mitteleuropa voreingestellt -ROM...
        Leider konnte Ihre hochgeladene Datei nicht gefunden werden. Laden Sie die Datei neu hoch.
        hope you can use this.
        what about crewrktablets.com ????
        good luck
        gefattern
          Hi focussoft
          one more
          http://freaktab.com/forum/tv-player-...ch-for-MK808B=
          http://vondroid.com/forums/mk808b-of...-firmware.224/
          hope it helps
          In VonDroid you have to registrated before you can load anything.It was only the MainThread Page.
          Remember many of this Sticks have Wifi Solder Bugs ( to many Solder on it /shorten the Wifi)
          gefattern
            i didn't know about the wifi issues , ill look in to that
            i need some time to weed through those pages lol
            didnt know there were also german forums about the mk808 ,interesting (i can read that)
              ok , i think i know what your talking about now , the antenna coax soldering
              i already replaced my internal wifi antennas with original 2.4Ghz router antennas a while back
              i have full signal now
              also put bigger coolers on the chips
              but my wifi is switching off and on , and only for a short time , and also just randomly
              sometimes i can watch a whole movie and sometimes only 10 minutes before it happens
              thanks for your help so far
                Hi focussoft ,
                hope you find a solution.Somewhere here i read that wrong WIFI Drivers making this Problem.Chip ID , Driver search.
                nice Day
                gefattern
                  Thanks for checking in to this
                  I gave up on it though
                  Just received a mini m8s II in the mail and that is going to be my new project
                  Sent from my 6045O using Tapatalk
                    Hi focussoft ,
                    nice to hear , good luck.
                    gefattern
