SCISHION V99 Magic, Amlogic S912 2/16, Dual WiFI, Gig Lan BT4
    Thanks to Lightinthebox we have a a quick first look at the V99 Magic S912 2/16GB
    A good looking 2 tone unit Black Glossy Top and all plastic some Ventilation on the underside.
    Amlogic S912 Octa-Core ARM Cortex-A53 up to 2.0GHz
    GPU ARM Mail-T820MP3 GPU up to 750MHz(DVFS)
    CPU Type Octa Core RAM 2GB DDR3 ROM 16GB NAND Flash
    Power DC 5V, 2A adapter included Net Weight(kg)0.75
    lighinthebox
    Bit of a look see on the inside to see what makes it all happen
    Top of PCB , well actually the underside as PCB is mounted heatsink down
    Nanya Ram, Forcee emmc AP6255 WiFi.
    Heat sink on secure
    Under side not much here Click image for larger version
    Closeup of the Bits
    Ports etc, 5vdc 2amp, SPDIF, RJ45, HDMI and 3 x USB2 ports Click image for larger version
    WiFi Antenna, weight block in the Base. PCB is mounted upside down the Heatsink of the Cpu is a few mm's from the weight block
    easy to mount some 5mm thermal Pad if required yet to be thrashed
    Power LED dull Red when Off and dull Blue when on will not be annoying and the IR pickup for remote. Click image for larger version
      After an Update the SCISHION V99 Magic, Amlogic S912 2/16, Dual WiFI, Gig Lan BT4 how now become very usable indeed.
      Original firmware dated way back in September was not polished,with newer firmware dated late October things moving along.
      Running the V99 for a few hours after update no Major problems or issues, Heat no Melt Down Temps Mid to Hi 60c when pushed.
      Found that both WiFi, Ethernet speeds good at this location, and overall performance was on track for this Breed of Media Player.
      So lets have a look at what it has
      Standard MBOX UI clean and does the job well, many variants about this one is ok, you can install others if you wish.
      The Unit has Proper Root with Notifications with the current updated firmware.
      Out with the OLD
      In with the NEW
      A1Ram Benchtest
      Full Details > http://browser.geekbench.com/v4/cpu/1124905
      Full Details > http://browser.geekbench.com/v4/compute/249681
      http://www.gearbest.com/tv-box-mini-pc/pp_449443.htmlearbest
