RK3368 - True octa-core November Update
i have 30x reset make.. is go not in the recovery:
Loader mode is needed in order to flash ROMs. If you simply connect your Android TV Box with the a USB cable to your PC and power it on, you will only get ADB mode, which will not work.- Plug in the USB cable to a PC and the Android TV Box.
- Press and hold the reset button. (On the Z4L/Z4 it will be located on the bottom of the box. On some others it will be in the A/V port, so use a toothpick or paperclip).
- Plug in the power adapter while still holding the reset button.
- 4 seconds should pass before it is in Loader mode.
- Let go of the reset button.
DO NOT TRY TO PUT A THIN OBJECT INTO THE Z4L/Z4! There is no back (at least on the Z4L), which means you can go straight into the area of the PCB and possibly destroy something or disconnect the antenna cable.
<----- no work ..
the box restart after 15 sec and go not in Loader/recovery .. what i make wrong ..
only ADB is going .. the driver for the Flashing ( Device Manager ) Ropckchip is not installed/installing...
Originally posted by MrFinner View Posti have 30x reset make.. is go not in the recovery:
<----- no work ..
Originally posted by MrFinner View Posti can not in the Bootloader ..
i have flash the RK3368 - True octa-core November Update
install and have a bug .. can not reboot or install TWRP ... no bootloader and no recovery...
thx for your help ....
I know. it has also worked 2x. only after flashen of the T051 from November does not go any more. I have tried it 50 times. I hope this soon update gives where the reboot bug is repaired or Fixed gives. this would be great.
the driver ADB is even installed.
are there still other possibilities? to the example dumpen?
or make I with the Bootloader what Wrong?
Originally posted by MrFinner View PostI know. it has also worked 2x. only after flashen of the T051 from November does not go any more. I have tried it 50 times. I hope this soon update gives where the reboot bug is repaired or Fixed gives. this would be great.
I have a new clean System installed win8.1 and i have install only RK4.4 Driver .....
The System Found: T051 Drive // MTP Installed // ADB
Androidtool 2.35 found only the ADB for the Box
i have test on 3 different USB com ports and different 3 Cabel and i can not in to the bootloader...
I put the cabel in the OTG port and i have 3xtesting the 4 sec press method and 3x 15sec the Reset Button Method and Put the PWR cabel in (pressing The Button all the time )... no Black Screen or Installing a driver ... i can not in the bootloader ....
GEFATTERN!!!
BIG BIG THANK! The Maskroom Mode have help!
One problem i have ... i have the orginal Z4L Stock Firmware Rom on my box .. the problem is .. the WIFI ...i can not WiFi set ON ..
All Firmware i found have a AP6335 .. on my Z4L have i a AP6255...
Big Thanx for helping info for my problem !!!
There are currently 2589 users online. 0 members and 2589 guests.
