Regards.
MK808b external player active issue.
Hi, I am new at this and need some help, I bought an MK808B which was working fine and setup with XBMC. Someone had logged on with their email to the playstore and did not supply the password. I decide it to reset to factory default. After reseting the factory default I lost the XMBC then I installed MX player and XMBC but not when I try to start any video in Mas UP I get the error "External player active" and it is not working at all. Please help.
Regards.Tags: None
Hi and thanks,
I did use the XAF XBMC and MX and installed MX first then XBMC still the same issue. Where can I get a copy of XBMC that does not use external player so I can try it. By the way here what I tried so far.
Reset to factory default before every different try.
Installed MX then XBMC
Installed XBMC then MX
Installed XBMC only
All gave me the same error "External player active".
Thanks in advance for all the help.
Installed XBMC only
You can get the regular XBMC from here:
There are currently 2053 users online. 1 members and 2052 guests.
