CHUWI HiBox Mini PC Android 5.1 + Window 10 Dual OS 64bit
Originally posted by afdude View Postis the remote supposed to come with a dongle( i am thinking it does)? Mine did not have it inside the remote body under the battery cover or anywhere else in the box. Never fails, its always something!
Ask the supplier if they can send you one.
air mouse works great. but prefer the Rii8 I have instead. Windows seems very snappy, turned off alot of useless junk. Decided to go with Windows Defender/Firewall enabled instead of adding processes by using third party antivirus. Using the box for my SlingTV service since I cut the cord. The video is much better/smoother/sharper on the Intel onboard vid than the Minix X8-H plus I was using. Havent even tried the Android side yet as I've really no need thx to Win 10. Booting seems very quick, I measured at 11 seconds from the button press so its pretty darn good. Havent tested anything in relation to the Fat32 limitation yet. Im sure we can get around this somehow, have to do more digging. Thats where im at so far.........back to it!
That is one of the benefits of Windows. It just works first time and every time exactly as you would want.
There should be no file format limitations with Windows either.
A case of as long as you know the limitations then it will work a treat, especially with Kodi.
Originally posted by afdude View Posti must have misread what you typed earlier on about limitations of 32gb from an older driver. My apologies. But yea it would be nice to be able to use something larger if you dont have a network/samba share active.
The limitations that I have found are with some larger SD cards but others have reported that others work, so will be variable.
No problems in reading FAT32, NTFS and exFat for those cards that do work though.
Using NTFS in Android will be more of an issue with android though at the moment but I am playing with getting root and porting Marshmallow X86, although it's a long process.
Mame64. Snes9x. PCSX2(playstion2) found in pre configured. Using my own arcade stick I built. Now I can play in the living room as well on the arcade machine! PCSX2 plays suprising well on this little machine.
hope the link was ok, do a search for PCSX2 or playstation 2 emu. there is a link there to pre configured version that works relatively well. Plays full framerate/sound on regular pc of course too.
Finally got Kodi back in and working great using 17. No more BS about it not working on older android versions etc etc. As much as I love to fiddle around on android, Windows is where its at with me personallyCheers.
There are currently 1900 users online. 2 members and 1898 guests.
