mxq pro 4k android 6.0 S905X firmware
    I have the same problem as carlosotu. The link above does not contain any file. I need the .img file to use via USB Burning Tools (for MXQPro-SV605P S905X KM201705060006), I don't need .rar or .zip files to put on SD card because the box seems to be bricked and the red light never turns into blue. can anyone help me?
      Try this link
        Thank you very much. The link worked and revived my TV Box. I am really grateful.
          I have 2 problems with the firmware. Wifi does not get enabled and also the status & notification bars have been hidden and I cannot get them back at all. Do you have any solution?
            Have on idea how to help you. The firmware works great on my mxq pro.
              My TV box is mxq pro 4k s905x 1g/8g android 7.1.2, This firmware can't be used for it.
              My TV box get bricked
                i Have MXQ PRO 4K with amlogic S905x 1gb ram and 8gb rom *WRITTEN ON BOARD* (H234 V2.4 2017-10-16)
                i want firmware this !!
                please help me to fix
                Attachments here images .
                Image 2137333081 hosted in imgbb.com
                  hi bro you have new firmware for this box ?
                    Originally posted by cbushjr56 View Post
                    Tanks man !!!
                      My TV box is mxq pro 4k s905x 1g/8g android 6.0.1 and would like to upgrade it to V7, can you help?
                        BOA TARDE ALGUEM TEM A FIRMWARE PARA TV BOX MXQ-4K MODELO
                        XT-MX4VN
                        _v10
                          Try my ROM for s905x devices, works well on my mxq pro 4k that came with 6.0
                            Hey guys! Any working link to the firmware file? MEGA doesn't allow you to download large files saying "Transfer quota exceeded"
