Firmware for MXQ m201
    Hello,
    i have a noname tv box and search for a new firmware.
    Manufacturer: MBX
    Model: MXQ
    Android: 4.4.2; 20150820; SDK19
    KERNEL: Linux version 3.10.33 (tanwei@tanwei) (gcc version 4.7.3 20130205 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.02-01-20130221 - Linaro GCC 2013.02) ) #4 SMP PREEMPT Fri Jun 26 12:34:17 CST 2015
    CODENAME: REL
    Mainboard: m201
    BRAND: MBX
    CPU_ABI: armeabi-v7a
    CPU_ABI2: armeabi
    DEVICE: m201
    DISPLAY: KOT49H.20150820 test-keys
    FINGERPRINT: MBX/m201/m201:4.4.2/KOT49H/20150820:user/test-keys
    HARDWARE: amlogic
    i have many firmware found on
    CHINA GADGET REVIEWS covers the latest gadget news, reviews and tech deals on tablets, mobile phones, computer accessories, DVD, digital cameras, GPS, laptops and netbooks, focusing on China's market devices.
    example
    Archive tpl-justop-mxq8188-20160512
    Image file name: m201-ota-20160130
    Firmware: Android KitKat 4.4.2 stock
    Image file size: 695 MB
    Platform: Amlogic S805
    Build number: m201-user 4.4.2 KOT49H 20160129 test-keys
    can i use this ota
    i dont understand to find the firmware
    need help please
    guss from hannover
    Yes you can try.. always have a backup of working rom on external CD first.
    Or u could install twrp, and flash zip files from there.
      Thanks, i don“t have a backup or a external cd.
      With twrp I have made bad experiences. On 2 tv dongle was the play back not successful. The original stock rom the manufacturers did not work.
      There is another possibility to create a backup?
        hotte96 you can try this download worked on my box KOT49H 20150720 test-keys from here http://chinagadgetsreviews.com/downl...-tv-box-2.html...
        it works and has working wifi working remote...I have found some of the newer firmwares on there for my mxq box the wifi does not work...
        update just installed this droibox firmware http://chinagadgetsreviews.blogspot....at-442_17.html on my mxq amlogic s805
        I am now upgraded to KOT49H.20160129 and controller and wifi all working fine...
        it left all my preinstalled apps and kodi intact and I did not even have to reconnect to wifi... PS. use at own risk
