NEOMODE CUSTOM ROM - MK808B PRO 4K - Version 2.0 - 20170101
    Here is the New Neomode Custom Rom for the MK808B Pro 4K.
    The Rom is Build from New Sources for S905.
    What is Working?
    - Wifi
    - Bluetooth
    - USB Touchscreen Support
    - Support for external Ethernet Devices
    - Support for GamePads
    What Software it, brings?
    - Freaktab Media Center Version 19 thanks to Louis
    - Petrus Reboot App
    - YouTube
    - Hulu App
    - MiXplorer File Manager
    - Netflix
    - AdAway
    - Chrome Browser
    What did not Work?
    All is working fast and Stable.
    Any Special Features?
    - Yes, the Device can be Controlled from your Tablet or Mobile Phone with the Android TV App from Playstore.
    - Root Unroot from Setting
    - GamePad Settings
    - HW Monitor
    Where to Download?
    Have Fun !
    Regards
    Neomode
    Thanks Neomode!
    My MK808B Pro arrived last week and I am currently flashing this. Look forward to trying it out.
    ::EDIT:
    Finally up and running. I must say I like your added features!
    Your extra settings under "Settings" are very neat and handy. Easily installed root.
    I do have one question (apologies if this has been noted elsewhere) and its in regards to the "Home" button on my wireless keyboard. I'm used to it bringing me to the app home screen. It now opens the home page of the browser. Is it possible to switch this easily?
    Thanks again!
      Yes should be, let me do a Test here.
      regards
      Neomode
        Hi
        quick question:
        i have a mxq pro 4k (the p201 one) this firmware it's compatible with this?
        does it have the chromecast service?
          Don't use it with this Device! I release a extra ROM for that the next Days.
          regards
          Neomode
            Hi neomode!
            Do you know if the rom will work on Nexbox Mxq Pro? Because I have not found custom roms especiall for this model and stock one is so unoptimized it almost makes the box unusable. It would be awesome if your rom is compatible, please let me know.
            Happy new year!
            edit: these are box's details
            NEXBOX MXQ PRO
            Board:
            MXQ 905 V2_0 2015112
            WIFI:
            Realtek 8189etv (NO Bluetooth)
            Ethernet Transceiver:
            IC+ ip101
            NAND or eMMC:
            NAND
            Board pic:
            Software:
              Try it without any guarantees.
              it can work. But I will release a mxq pro 4K this week
              Regards
              Neomode
                if mxq pro 4k has more possibility to be fully compatible, I will wait for that one. Thank you again for your work!
                  Great boot animation, takes me back.
                  Showing our age.
                    regards
                    Neomode
                    I was able to get it figured out For my Microsoft All-In-One Media Keyboard (104 keys) I edited the Generic.kl at this line:
                    Code:
                    key 172   EXPLORER
                    to
                    Code:
                    key 172   HOME
                    Now my "Home" key brings me back to Home screen again.
                    Also going to remap the key beside this one to something else so as not to duplicate, just learning what can be done.
                    Code:
                     key 144   HOME
                    Everything else running great otherwise. Thanks again!
                    ::EDIT:
                    To make it "cleaner" and not edit the generic.kl I ended up creating Vendor_045e_Product_0800.kl for my specific keyboard. Seems to work so far.
                    Ended up just swapping the key codes, don't know why I didn't just think of that initally, d'uh! lol.
                    Cheers all!
                      [QUOTE=neomode;n619765]
                      What is Working?
                      - Wifi
                      - Bluetooth
                      - Petrus Reboot App
                      - YouTube
                      - Hulu App
                      - Netflix
                      - AdAway
                      - Chrome Browser
                      What did not Work?
                      - GamePad Settings
                      - HW Monitor
                      Where to Download?
                      Have Fun !
                      Regards
                      Neomode
                        I instal in tv Stick: Ts Transpeed 4K, S905 2G/16G , " wifi not work ",
                        however it seems to be stable and fast
                          regards
                          Neomode
                          any eta on that been waiting very long time.................
                            I got the firmware of the Ts Transpeed S905 2G 16G (clone to clone) was just questioning the seller of Aliexpress, link:
                              This kinda worked on the Mini M8S, it gets kinda jerky from time to time, not sure if its something normal.
                              EDIT: after a while of using it I think it will not work on the Mini M8s, it lags a LOT :'(
