NEOMODE CUSTOM ROM - MK808B PRO 4K - Version 2.0 - 20170101
Originally posted by tiff_lee View Post
Have you even read this thread? When asked he clearly stated it wouldn't and that he would release a version soon, that was followed by about half a dozen posts talking about the pro 4k version.
Originally posted by gerardox360 View Post
Yes, I have already read the thread, and you asked for the (p201 version) , I don't really know if the differences, so I asked if this would work. Already installed OpenElec with, for the V1 version (Blue board) There's no need to be rude.
While I did specify P201 this lot didn't.
Originally posted by Slime View Postif mxq pro 4k has more possibility to be fully compatible, I will wait for that one. Thank you again for your work!
Originally posted by veclinux View Post
any eta on that been waiting very long time.................
Originally posted by feira91 View Posthello neomode can i know when you going to release the same custom firmware for MXQ PRO
Originally posted by bartj12 View Post
Hopefully are you recovered from the flu. I was wondering when we could expect the ROM for the mxq pro 4k?
Thanks!
Well, I am also putting in my request for the MXQ Pro 4k (p201) version of your firmware. If you dont have one of those for testing, I have experience building kernels and ROMs for Qualcomm and Broadcom devices and would be willing to maintain such a version or help in any way I can.... just point me to the repo in a PM or something if you wish.
I tried the ROM on my p201 box, knowing that wifi will probably not work. After that I tried some different ROMs which led to a problem.
On the ROM I am on right now, I am not able to get into recovery with the toothpick method, which worked fine before.
I tried several things to get back to the stock ROM or Neomode's ROM, but nothing worked.
Can you give me any advice how to flash the recovery and/or bootloader from the running system with a terminal emulator?
I assume that flashing a different BL or recovery gives me back the ability to use the toothpick method.
EDIT: The box is not recognized via male-to-male USB cable using the USB-port on the back of the box. So any fastboot/adb solutions won't work!
Originally posted by Heffernan View PostI tried the ROM on my p201 box, knowing that wifi will probably not work. After that I tried some different ROMs which led to a problem.
Originally posted by oneleft View PostWell, I am also putting in my request for the MXQ Pro 4k (p201) version of your firmware. If you dont have one of those for testing, I have experience building kernels and ROMs for Qualcomm and Broadcom devices and would be willing to maintain such a version or help in any way I can.... just point me to the repo in a PM or something if you wish.
I can support with the testing part...
Regards,We’re the middle children of history, man. No purpose or place. We have no Great War. No Great Depression. Our Great War’s a spiritual war…
I posted on the thread for your previous ROM. I just tried this one as well and it does not work correctly either. FWIW, I have an MXQ Pro, S905 with 8189ETV wifi chip. Board is marked
Model: MXQ-S905-D16
Ver:1.0
Date: 151021.
I accidentally bricked it and tried this firmware. Where others would not load using the USB Burn Tool, this one did. The WIFI however does not work.
Since I was able to flash using your firmware and my box was resurrected, I was able to flash with "stock" firmware from:
which does run all the hardware, including the remote.
Like other stock firmwares though, this one has issues. The biggest is that the Google Play store does not work right and some apps that I know will work are flagged in Play as not for the version of Android on the box. I have to sideload apps. That and the MBOX launcher is silly and I have to use Nova Launcher.
Perhaps you could use this firmware as a basis for a new build for S905 RTL8189 boxes.Last edited by Kragmeister; 03-10-2017, 12:32.
@Kragemeister
In Thread "NEOMODE CUSTOM ROM MK808B PRO S905 & MXQ PRO S905" / http://freaktab.com/forum/tv-player-...5-mxq-pro-s905 on
Post #197 from KyleRiemen:
//07-24-2016, 03:38
//Originally posted by blackbird920 View Post
//nice custom rom, if the wifi of mxq pro works in new version i'll donate too.
//thanks
//If you want Wifi to work just put this file https://www.dropbox.com/s/jd8xuuoqka...8723bs.ko?dl=0 into /system/lib/ , replace the original one, set permissions to 644 and reboot. It is actually only the 8189es.ko //renamed to 8723bs.ko.
and on Post #249 from dylan54:
10-19-2016, 08:17
Thank you for the nice rom.
FOR 8188EU USER
My box is:
MXQ-S905-D16 = MXQ PRO 4K
V 1.0
DATE 151021
RT8188ETV chip on motherboard
Whith NEOMODE rom wifi not working? NO PROBLEM
download attachement and uncompress,
in /system/lib delete the 8723bs.ko
8188eu.ko and put on it on /system/lib
and after rename in 8723bs.ko, chmod to 644, reboot.
good rom solution for the community.
Thank you in advance.
Perhaps you can try the rom from Post #300 from pawhtiobo
03-03-2017, 04:11
Originally posted by mike1111m View Post
got it to boot no wifi or ethernet?
A few posts back, I think I saw a workaround related to replacing the .ko module of the wifi to make this ROM work.
Also, I found a modified version of this ROM here:
http://freaktab.com/forum/tv-player-...testing/page13
This one already has the correct driver, and it works!
Regards,
Originally posted by Kragmeister View PostI posted on the thread for your previous ROM. I just tried this one as well and it does not work correctly either. FWIW, I have an MXQ Pro, S905 with 8189ETV wifi chip. Board is marked
Model: MXQ-S905-D16
Ver:1.0
Date: 151021.
Hope this help
Hi to all!
Thank you for this awesome rom, I tried on my MK809V TV Stick. Rom successfully runs but I can't use mouse But maybe, USB drivers are problem, sorry I'm not sure because I know nothing about roms except how to install them
Is thre any way you can implement drivers from this rom:
(on this rom works everything except ethernet hub)
To yours? I know that I'm asking to much, but I think it will be awesome to have you rom fully functionaly for us with this stick.
Please let me know
Originally posted by neomode View PostWhat you mean you can´t use a Mouse?
Did other USB Devices Work or USB general not Working?
Regards
Neomode
Generaly USB wont work.
EDIT:
I found modified rom and installed, now USB and wifi works. But I have problem with ethernet cable. Also I uploaded on topic drivers that came with CD. Can you check it and please can you tell me how can I manualy install on box? Also I don't have root access, help?
Code:http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/others-ac/638013-transpeed-mk809v
There are currently 2102 users online. 4 members and 2098 guests.
