Linux for Amlogic S802 \ S812
Test alpha images. The main purpose - a basic assessment of health schedules (a bunch of the kernel + dtb). To check system startup you need to activate the multi-boot (all required files included in the images). On my sample s812 activation multi-boot is possible only with SD card, maybe on other devices it works with USB. After activating a multi-boot system running from USB (I'm running every test with USB flash drives). Please check the possibility of launching on the platform s802. Pay attention - the system must copy the appropriate dtb file with the name "dtb.img".
Tags: None
menthorul you have mx3 clone box with s802 cpu ? I have mx3 clone box with demaged nand and i want to boot android os or similar os using sd card. balbes150 is posible to boot linux on mx3 clone box and do i need to modificate the u-boot file on sd.Do you have some instruction or vidio how to boot linux os with sd
Originally posted by tani666 View Postmenthorul you have mx3 clone box with s802 cpu ? I have mx3 clone box with demaged nand and i want to boot android os or similar os using sd card. balbes150 is posible to boot linux on mx3 clone box and do i need to modificate the u-boot file on sd.Do you have some instruction or vidio how to boot linux os with sd
You have connected the console UART ?
Originally posted by Kentril View PostI've tried booting from SD Card with my MXIII 4k S802 - It seems it has tendency booting from SD card, but then only black screen. Once I managed to see LibreElec Logotype. Does it matter wich build I have on internal memory? I have Teamwin recovery. Thank you
or this https://drive.google.com/open?id=0By...WU0R0U5RG85Q3M
or the img from my link https://drive.google.com/open?id=0By...EFkblRXRm5LWlE
To run the system you need to manually copy it to the root of the media the correct dtb file with the name "dtb.img" .
i have usb to ttl but i am not able to see any mesage in putty.What console uart you suggest.I have 2 different usb to ttl but none of them works.Its look like the usb to ttl are only compatible with aurdino or i have made some mistake connection the cable with box.
Any of these modules USB to TTL is suitable for the connection. If there is no display information - so not correctly configured. You can try to swap the Tx and Rx contacts. Sometimes they are signed "on the contrary". More detailed information on configuring the UART is in the section of this forum about S905.
Have you trayed this firmware with sd card method https://drive.google.com/open?id=0By...mVQUWRRM3VHSVk
Or just simply unzip file onto SDcard? Thank you
There are currently 3961 users online. 0 members and 3961 guests.
