I mean, is there a Linux device mapping for it?
Linux for Amlogic S802 \ S812
Hi Everyone i need help, i try install to linux ubuntu mate my device but i have problem. My tv box its Measy B4A working on amlogic s812 and its twin tronsmart mx III plus same parameters.
I try everything and i use all dtb. files in base but nothing working my device. Librelecec working i use this thread https://forum.libreelec.tv/thread/28...ges-for-7-8-x/ use image from mxIIIplus 2G working perfect why linux dosen,t start ??
balbes thank you so much for your work
I'm trying to install armbian in a matricom gbox q2, which is a s812 2gb ram with a mali-450
1) Downloaded this image: Armbian_5.41_S812_Debian_stretch_3.10.108_server_2 0180402
2) Burned to an sdcard
3) Booted box with reset button
4) When it boots, there an initial screen with lots of artifacts, then video signal goes down and never comes back after waiting a few minutes.
I tried with a bunch of dtb without success.
I've sucessfully booted a libreelec image from the community (LibreELEC-S8X2.arm-8.2.3-M8S-PLUS). So I though of opening this image to copy the dtb.img inside it and try with it, but nothing again.
Any ideas? Thanks
Originally posted by balbes150 View PostFiles from this LE version is not suitable for Armbian. Send me dts files and if so , output from the UART console, which describes which dtb is used from these 8 options.
For the others, I would need to confirm which is actually being loaded. I'm not entirely sure how to do it, I'll do some research.
Hello. I own this tv box https://www.banggood.com/MXIII-4K-2G...-p-952057.html (K200 version). The problem is that i cannot make it boot ambian. There is a screen flickering and then the monitor deactivates and nothing for half an hour or so. Any idea?
There are currently 2836 users online. 0 members and 2836 guests.
