Beelink GT1 Ultimate 3/32Gb DDR4 Dual WiFi Gig lan BT4.
Hi to all. I'm thinking in buy a GT1 Ultimate but i see the new GS1 with the newer Allwinner H6 but only with 2mb DDR3 and 16mb emmc. What do you recommend?
I'm reading about a lot of problems and cooked roms for the GT1 Ult. But GS1 appears better but is a mistery yet..
Anyone can give me some light?
Thanks and regards.
I've just got my brand new one. I cant find answer anywhere about the possibility of having 2 gamepads to play.
If its possible, as anyone tried and if it works? I was thinking of ordering 2 controllers but i want to be sure its possible for 2 player to play at same time before i buy.
Also, any recommendation on controller i'm very much thankful
Originally posted by krispassionI've just got my brand new one. I cant find answer anywhere about the possibility of having 2 gamepads to play.
Edit: I read someone else using 3 controllers simultaneously. They had 2 G4s controllers and one wired xbox controller and everything was fine for them. The difference between G3s and G4s is style. G3s is ps4 style and G4s is Xbox style.
Sent from my XT1687 using Tapatalk
There are currently 2477 users online. 0 members and 2477 guests.
