Thank you for all your time and patience. It is greatly appreciated.
A95X S905X bricked by SD card update
So I tried to do the Xannytech mod on my A95X and I followed the instructions for an SD card update, I had the droid on the screen and it was doing it's update, and then the box bricked. Completely. All I get is a red light on the box with no display at all. I have tried to use the USB flash tool, but the box is not recognized by my computer at all, no beeps no new hardware, nothing. I have tried the videos posted on tvboxforums, as there was a business card included with the box that said to go there for support, but nothing there is helping at all. Does anyone know how to revive this thing from the red light of death, or do I just need to send it back as DOA? It's very frustrating as the the box has so many flaws that the Xanny mod fixes and if I am not able to update it at all, then I won't be buying these ever again for any of my friends.
Thank you for all your time and patience. It is greatly appreciated.Tags: None
Well after figuring out what pins to short out (on the underside of the pcb, what a pain), the box only goes to 2% and then fails miserably. At this point I am going to call them bricked beyond repair. Apparently the newer a95x boxes have issues with updated firmware??
[17:29:35 740][Global][Inf]--Update HUB6-8 \\.\USB#VID_046D&PID_0B06#6&3520cc6b&0&8#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[17:29:35 741][HUB6-8][Inf]--Update device path
[17:29:35 791][HUB6-1][Inf]--CloneImageProxy
[17:29:35 791][HUB6-1][Inf]--Connect path=Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26/P0/P0/P0
[17:29:35 791][HUB6-1][Inf]--Start burning...
[17:29:35 841][HUB6-1][Inf]--------------ERASE BOOTLOADER------------
[17:29:35 842][HUB6-1][Inf]--2-2-0-0
[17:29:35 842][HUB6-1][Inf]-------------Download DDR.USB-----------
[17:29:35 842][HUB6-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[17:29:36 343][HUB6-1][Inf]--Control write pll reg1 0xd9000000:0x00005183
[17:29:36 843][HUB6-1][Inf]--Write initial succeed
[17:29:36 843][HUB6-1][Inf]--Upload encrypt at 0xc8100228
[17:29:36 843][HUB6-1][Inf]--ulValue = 0xadfc318c
[17:29:36 843][HUB6-1][Inf]--Read encrypt value succeed
[17:29:36 851][HUB6-1][Inf]--Transfer complete
[17:29:36 852][HUB6-1][Inf]--Run at address 0xd9000000
[17:29:36 852][HUB6-1][Inf]--RunInRam succeed
[17:29:37 193][HUB6-1][Inf]--IOCTL_IDENTIFY_HOST_Handler ret=-5 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning.
kreator, I am in the same boat red light blinks, chirping noises/shorting and nothing on hardware front. I believe it is pins 1-2 i am shorting. But no matter what combination I try, reset button, usb cable, power no power still nothing.... same old red light of death.. there has to be a way to wake this things up (flashed wrong TWRP on it and been dead since). Specifically I have a Puersit I9X Amlogic s905x 1gb-8gb.
yes i have tried the other pins, the only actual, physical short on the whole board is pins 1-2. if tried 3-4 and others and no luck. trust me i have tried multiple .img's, multiple versions of usb burning tool and multiple combinations of usb, power, reset and such in all orders possible. The box continues to have red light of death that's about it. With that said, i may jump ship and give up.. what im looking for a is a great little box that can handle the directv app, and acts as a tablet essentially. smooth quick interface and easy control.... this amlogic s905x was not that great that is why i was tinkering with it in the first place. any suggestions on a better overall box?
There are currently 1903 users online. 0 members and 1903 guests.
