A95X S905X bricked by SD card update
Well I just bricked another one of these POS's. 3 out of 4 boxes bricked. Seriously, what the hell is going on. They wouldn't flash with USB burn tool, they would fail at 2%, and flashing them with TWRP broke them completely. Nothing but red light. I think it's time to toss these boxes out and go with something better.
Originally posted by kreator View PostThe Yundoo was also bricked by flashing TWRP? I think the catch here is never flashing TWRP on the machine but booting from it in a SD card only to backup and restore.
Originally posted by kreator View Postoh I see. Maybe its time to solder a UART connection to it and try to recover...
I'm actually having the same problem. Mine is the A95X_DDR4 v1_1 20160906 board revesion.
It has teh Samsung eMMC chip on it. Same chip layout posted by Kuno.
I got lucky and found data sheet on this chip: http://www.datasheetspdf.com/datashe...WEPD-B031.html
I have not had any luck resting it though.
Originally posted by Kuno View PostWell after figuring out what pins to short out (on the underside of the pcb, what a pain), the box only goes to 2% and then fails miserably. At this point I am going to call them bricked beyond repair. Apparently the newer a95x boxes have issues with updated firmware??
[17:29:35 740][Global][Inf]--Update HUB6-8 \\.\USB#VID_046D&PID_0B06#6&3520cc6b&0&8#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[17:29:35 741][HUB6-8][Inf]--Update device path
[17:29:35 791][HUB6-1][Inf]--CloneImageProxy
[17:29:35 791][HUB6-1][Inf]--Connect path=Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26/P0/P0/P0
[17:29:35 791][HUB6-1][Inf]--Start burning...
[17:29:35 841][HUB6-1][Inf]--------------ERASE BOOTLOADER------------
[17:29:35 842][HUB6-1][Inf]--2-2-0-0
[17:29:35 842][HUB6-1][Inf]-------------Download DDR.USB-----------
[17:29:35 842][HUB6-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[17:29:36 343][HUB6-1][Inf]--Control write pll reg1 0xd9000000:0x00005183
[17:29:36 843][HUB6-1][Inf]--Write initial succeed
[17:29:36 843][HUB6-1][Inf]--Upload encrypt at 0xc8100228
[17:29:36 843][HUB6-1][Inf]--ulValue = 0xadfc318c
[17:29:36 843][HUB6-1][Inf]--Read encrypt value succeed
[17:29:36 851][HUB6-1][Inf]--Transfer complete
[17:29:36 852][HUB6-1][Inf]--Run at address 0xd9000000
[17:29:36 852][HUB6-1][Inf]--RunInRam succeed
[17:29:37 193][HUB6-1][Inf]--IOCTL_IDENTIFY_HOST_Handler ret=-5 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning.
Also if it's windows 8.1 or newer check if you get error 43 in device manager when you get the host error."HANDS ARE NATURES FORKS" -Rigby
Originally posted by Kuno View PostI just boomeranged it to Amazon. But if I get another box that does this, I will try your suggestion."HANDS ARE NATURES FORKS" -Rigby
I just purchased a few of the a95x boxes from Amazon as well. I cant use the USB Burning Tool to install custom firmware on any of them. Whenever I try it fails at 2%. If I try the stock firmware it loads with no problem. If I use the SD card method to flash custom firmware I get bricked with the red light. Shorting pins 7/8 allowed me to flash stock using usb burning tool.
Has anyone figured out how to flash custom firmware with these new boxes?
Ive noticed that all of the new a95x's that I have that won't update with a custom ROM have an R4 in a circle on the bottom of the box right under the rom size. R4 also appears on the bottom of the packaging. The build date is also 12/30/2016. Can anyone else confirm?Last edited by Rccm1112; 07 February 2017, 16:17.
There are currently 2195 users online. 0 members and 2195 guests.
