MECOOL KIII PRO Amlogic 912, 3/16GB Dual WiFi, Gig Lan, BT4, DVB S2/T2
    Click image for larger version  Name:	22.jpg Views:	1 Size:	65.6 KB ID:	623325
    Main Features:
    Amlogic S912 CPU with octa core is rapid and stable, it can give you a high-speed feedback and smooth response.
    Android 6.0: comparing to the former version, people can easily install or uninstall applications and games.
    Dual Band WiFi: 2.4G plus 5.0G can improve the speed which can implement multi-task.
    1000M LAN can improve the net speed and the performance to a large extent.
    Click image for larger version  Name:	20170117141616_36737.jpg Views:	1 Size:	137.1 KB ID:	623326
    Gearbest
    hello
    is it DVB-S2 DVB-T2?
      Specification
      Brand: MECOOL
      Model: KIII PRO
      Type: TV Box
      GPU: ARM Mali-T820MP3
      System: Android 6.0
      CPU: Amlogic S912
      Core: Octa Core
      RAM: 3GB
      RAM Type: DDR3
      ROM: 16G
      Max. Extended Capacity: 128G
      Color: Black
      Decoder Format: H.265
      Video format: 4K,ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS ,VOB,WMV
      Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
      Photo Format: BMP,GIF,JPEG,PNG,TIFF
      Bluetooth: Bluetooth4.0
      Power Supply: Charge Adapter
      Interface: AV,DVB-S2,DVB-T2,HDMI,RJ45,SPDIF,TF card,USB2.0
      Language: Multi-language
      HDMI Version: 2.0
      Other Functions: 3D Games,3D Video,DLNA,Miracast,NTSC,PAL
      External Subtitle Supported: No
      HDMI Function: CEC
      Power Comsumption: 8W
      RJ45 Port Speed: 1000M
      System Bit: 64Bit
      WiFi Chip: BCM4335
      KODI Pre-installed: Yes
      KODI Version: 17.0
      Power Type: External Power Adapter Mode
      Power Adapter Output: 5V 2A
      Remote Controller Battery: 2 x AAA ( not included )
      Product weight: 0.260 kg
      Package weight: 0.820 kg
      Product size (L x W x H): 13.00 x 12.00 x 3.20 cm / 5.12 x 4.72 x 1.26 inches
      Package size (L x W x H): 22.90 x 15.60 x 6.80 cm / 9.02 x 6.14 x 2.68 inches
      Package Contents: 1 x MECOOL KIII PRO TV Box, 1 x Remote Control, 1 x Power Adapter, 1 x English Manual
      Gearbest
        Ram is only ddr3 ? For this price is not logical
          Today we can have a bit of a look at the
          MECOOL KIII PRO Amlogic 912, 3/16gb DVB-S2/TV Dual WiFi, Gig lan BT4
          Amlogic S912 octa core ARM Cortex-A53 @ up to 1.5 GHz with Mali-T820MP3 GPU
          3 GB DDR3/16GB eMMC micro SD card slot up to 32GB
          HDMI 2.0a up to 4K @ 60Hz, 3.5mm AV (composite video) jack, AV, optical S/PDIF
          DVB-T/T2 and DVB-S/S2
          Gigabit Ethernet, WiFi 802.11 b/g/n/ac Wi-Fi, and BT4.0
          4x USB 2.0 ports
          DC 12V/12A
          Gearbest
            Hmmmmm 167 candian yikes lol
              Bit of a look on the inside to see whats going on
              Topside, Lid, Antenna
              Topside PCB
              Underside PCB
              Base with weight Block
              WiFi, eMMC, Ram, Realtek Ethernet thing.
              Rear Ports
              Side Ports
              While setting up box Google play etc performance feels ok Ethernet Good, Apps loading in fast
              The Android side of this feel on par so far with other test I have done on S912 Boxes
              Bench testing to come will see how it all goes
                Look at UI and system much the same as the rest Android 6, does have Root and option to enable lower task bar if required.
                Simple Mecool UI
                DRM
                Ram Truth
                Storage Truth
                SD Card Test
                CPU-Geekbench 4
                Full Details > http://browser.geekbench.com/v4/cpu/2641945
                Compute-Geekbench 4
                Full Details > http://browser.geekbench.com/v4/compute/686447
                Bonsai
                Vellamo
                3DMark
                CPU-Z
                As mentioned performance on par with other S912 media players so should do most to keep the user happy on the Android side.
                That's the easy part done now let's check out all about the TV side of this box.
                A separate app to run called DTV, will check it out to how good it can be for FTA TV.
                No Satellite stuff here to check.
                More to come.
                  Ran up the DTV app select Auto scan Hmm nothing...Ok help if we plug the TV antenna in first
                  And Second need to set the Media Player up to Australia found in DTV Preference
                  Click image for larger version  Name:	Clipboard01.jpg Views:	1 Size:	29.2 KB ID:	642996
                  Scanned and all channels found easy.
                  100% Sig and Quality, using Log periodic type antenna about 30k from the TV towers (bit of wet string would prolly do)
                  Click image for larger version  Name:	ANtenna.jpg Views:	1 Size:	38.7 KB ID:	642997
                  Picture Quality looks ok
                  Time between channel change 2~3 second failry quick
                  EPG looks ok easy to read, other functions to set up PVR Time Record, Channel Sort, Favorites, Parental Control
                  Easy as.
                  I find the Remote is Designed more for the TV/Sat function of the box than Normal Android.
                  I normally use the k400 logitech with android it not a problem here, other may find it a problem.
                  First thing get greeted with when running the DTV App
                  Menu to Select Country/Region, select DVT Preference
                  ONce set back to Installation and scan
                  Easy
                  EPG from Remote
                  All features selected are overlayed a top of the TV Image,
                  Was not able to snap TV Images only overlays at this stage.
                  All funtions are access from remote.
                  ON Screen Display (dark room picture lights out)
                  Edit Channel List
                  PVR Settings
                  PVR Storage Device
                  Favorite Channel to be added
                  Channel info and Sub titles
                  And a little music if the FTA gets to much
                  There is a little about the TV function easy as really if you have a spare PC monitor
                  and need a FTA this is an option to consider.
                  More to come as I find it
                    New custom firmware from superceleron
                    Freaktab
                      Nothing supernatural on the basis of factory firmware, production by template, oh yeah, launcher normal
                        Sorry
                        Don't get your point ?
                          I've been waiting to hear about one of these for a long time. Is it worth buying? And how much should I pay?
                          I'm currently running a Vigica C90.
                            Does anyone read this forum?
                              Yes i read it lol
