Realtek 1295 CPU with octa core is rapid and stable, it can give you a high-speed feedback and smooth response
Android 6.0 OS: comparing to the former version, people can easily install or uninstall applications and games
Dual Band WiFi: 2.4G plus 5.8G can improve the speed which can implement multi-task
1000M LAN can improve the net speed and the performance to a large extent
Gearbest
