Beelink SEA I TV Box Realtek 1295 Quad Core CPU - 2GB+16GB
Originally posted by KAA View Post
this box missing bottom navigation.. can someone add this feature...thanks
To get the navigation bar back it may be as simple as editing the build prop, Unless it has been stripped from the system UI app too.
In the Build prop there is this line
rkt.screen.HidenavigationBar=1
It could be as simple as changing the 1 to a 0
But with the lack of the stock firmware I would not advise changing anything in there as its so easy to get stuck in a boot loop by messing with the build prop One mistake & you will be boot looping (Soft Bricked)
For now your best waiting for the stock firmware to become available
G'day all here we go with the
Thanks to Gearbest and Beelink.
Already a few reviews around so I will bore with another
Whats in the Box
New look Beelink Remote and some reading material
HDD cover off
Place to slip that HDD in
Close up of where you can stick it, the HDD that is
Look at the inners
PCB Underneath not much going on here
Top View and the Thermal Business not to good by reports
Clock Chip
WiFi Chip
Ram K4A8G165WB-BCRC DDR4
eMMC Samsung KLMAG1JENB-B041 eMMC 5.1 x 2
CPU RTD 1295DD
Ports
And Finally some Information and Bench testing etc
DRM not even L3
Vellamo
Ram Truth
Storage Truth
A1 Sd Benchtest Ok speeds
Geekbench 4
Full Details http://browser.geekbench.com/v4/cpu/1959240
Full Details http://browser.geekbench.com/v4/compute/473071
These tests were done on the Original Thermal unit and temps getting into the 80c area when pushed
Will now do some more testing with modified thermal pad to see if things are sea worthy.
Quick look at the Record/PIP function what it has to offer
In Settings you have the option to choose hdmi 1.4 or 2
A very basic Interface for recording/pip etc
Picture in Picture mode
Can move it around or go fullscreen, certain part of the screen the pip disappears not sure why yet
A broadcast function
Yes found that one....just got to find a signal that stays on at the present drops off no HDMI....did record a small section looks ok..
A very Basic record/pip function indeed...
Just need to use a decent hdmi cableand the signals holds......I knew i had a knot in that cable for a reason
now its in the bin
A video recording FTMC on Beelink GT1 to a the Beelink SEA I TV Box Realtek 1295 Quad Core CPU - 2GB+16GB
Not to bad, recorder original file as a .ts not many settings to fiddle with (none).
Push play on one and record on the SEA 1, easy and done.
File format
Code:General ID : 0 (0x0) Complete name : C:\Users\Pat\Desktop\sea beelink\New folder\VID_20170227_212440.ts Format : MPEG-TS File size : 146 MiB Duration : 1 min 46 s Overall bit rate mode : Variable Overall bit rate : 11.5 Mb/s Video ID : 482 (0x1E2) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : [email protected] Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=30 Codec ID : 27 Duration : 1 min 45 s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Audio ID : 481 (0x1E1) Menu ID : 1 (0x1) Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Muxing mode : ADTS Codec ID : 15 Duration : 1 min 46 s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 spf) Compression mode : Lossy Delay relative to video : -83 ms
There are currently 2655 users online. 0 members and 2655 guests.
