Sent from my Redmi 3 using Tapatalk
128GB Samsung Micro SD adopted storage reports as 32GB
This card is genuine I was using on my PC and filled with 100+GB before I moved all this to another card and it was directly from Amazon not fulfilled. The card reports as 32GB in the settings on my Nexbox A95X 2GB 16GB box. But when I go to view what's on the card at the bottom it does show as over 116GB available. I'm going to try to get over 32GB of apps installed on the mounted card too see what happens but why before viewing in detail the storage reports as 32GB? Should I be concerned or is this an error? It's a class 10 card purchased late last year. It did warn me about possible slow speeds but apparently that's common place with Android 6.0.1 or which ever 6+ version is loaded on the box. I've got the latest OTA update installed from November last year.
Tags: None
How is the card formatted?
FAT32, exFAT, NTFS?
Try formatting it in Android.
Last edited by bluesmanuk; 21 January 2017, 22:35.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by modmouse View PostNot sure about this, I've plugged in my 3TB 3.5" hard drive and it seems to find all the folders and Kodi 17 RC sees them too.
Most SD card readers on these boxes do tend to be certified for 32Gb use, with some managing to read 64Gb and above but it can be a lottery.
I guess you can try to fill it to over 32Gb and see if the data can be read back.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk
USB is a different matter and of course in this case it has been formatted to be part of the internal storage.
There are currently 2068 users online. 0 members and 2068 guests.
