[Brick] MXQ PRO 4K RK3229
    Hello people,
    I just hard bricked my MXQ Pro 4k (the one with the red 4K on it) with a RK3229 chip.
    I was trying to flash a stock rom with batch tool v1.7, which failed multiple times. I then downloaded v1.4 to try again, but the language files missed. So I thought that the third button from the left was the "upgrade" button.... (I know... Stupid. Should have checked it first...)
    ~removed some dumb stuff I said >.<
    Attached some pictures of the board.
    Hope somebody can help me out!
    Alright, I finally made it to MASK ROM mode.
    I erased the flash with the EraseFlash option in AndroidTool v2.3
    Rockchip batch tool v1.8 now gives a blue square. (MASK MODE)
    But whenever I try to flash an MXQ PRO 4K RK3229 firmware, it fails (using the Restore option)
    It always returns a "Prepare IDB Fail". I'm really stuck at this point... :s
    Please help!!
      Wish I could help with the idb fail. I have the same bricked box and can flash in masked mode successfully but no dice on reboot. What firmware did you use?
        Hi tloader7 and others ,
        Dont use Batchtool , try it with AndroidTool 2.30 or 2.35 and first "erase IDB" wait till ready
        and then press "run" , single .img Files under Tab 2 / splitted under Tab 1.
        Maybe your Device can use Mos Roms for RK3229 , but first ask in the suggested Thread :
        http://freaktab.com/forum/tv-player-...w-rom-by-mo123
        good luck
        gefattern
          good luck
          gefattern
          My firmware don't work on c*** like that.
