Firmware request for m96x
Hello guys, I broke my m96x android box by modifying the build.prop and now it does not pass the startup screen. its stuck . i tried the bottom reset button, removed the plug while hodling the reset button and plug it in but nothing happened. can someone tell me how to flash this box and where to get firmware. i have other another m96x box that is working. how should i save the firmware from working box and how to flash it into broken box ? PLease help. thank youTags: None
Hi u can use thex96 firmware ... its compatible.. or Try to get ahold of the box seller and ask for the firmware, than flash it.
Does your box get recognized on the computer? you could use adb to reboot the box into recovery. Im not an expert on these things, just a beginner but i think its adb reboot recovery
Well before you try, i should warn you, there is a chance it wont work 100% so its on your resposibility. This is the firmware. http://freaktab.com/forum/tv-player-...m-probox-2-air. You can also use Libreelec, put it on an SD card to test it first https://forum.libreelec.tv/thread-3588.html
Edit: libreelec from sd card is the safest way and your chips is s905x not the s905
Originally posted by M96x View Posthi i just try to flash it using usb buring tool. its giving me hub2 error . i dontno what that means"HANDS ARE NATURES FORKS" -Rigby
Originally posted by M96x View Postok its giving me problem it says kodi jarvis fail due to missing sd card. when i tried to download kodi . i dont like this build. is there any other firmware ?"HANDS ARE NATURES FORKS" -Rigby
Some firmwares use different bootloaders that vary slightly and that's probably what's causing the issue. Spmc is kodi 16.1 with a few tweaks is all and it works better on these amlogic based boxes. Kodi itself doesn't have great support for these boxes anymore."HANDS ARE NATURES FORKS" -Rigby
thank you so much man. your are the best. atleast i fixed my bricked box lol. do you know why other firmwares did not work ? the file you gave me the link, what is the difference between that and other firmwares that did not work. im just trying to learn . I want to see if i can find factory firmware or close to it to flash it again if possible. the google play is checking for info for ever now lol.
i do not see a file manager in this firmware ? can you tell me how do you end task apps running in the background ? usually there is a navigation bar in the bottom but this one does not have one.
There are currently 1928 users online. 1 members and 1927 guests.
