Is there anything I can try before I attempt to get it replaced by the seller? That's not a headache I'm looking forward to.
MK809III appears to be dead?
I ordered one of these from Banggood a couple weeks ago and finally got it yesterday. It worked okay for an hour or two last night on my TV at home, but when I brought it to work to play with it, it doesn't appear to be interested in booting anymore. My computer doesn't detect it when I plug it into a USB port either.
Is there anything I can try before I attempt to get it replaced by the seller? That's not a headache I'm looking forward to.Tags: None
What actually happens when you plug it in? Anything on screen?
Is the blue power LED lit? There's a small hole on the back of the case, in the corner where the power lead plugs in.
Are you using the supplied power adapter? They're not very good and yours may have broken. Try a good adapter of at least 2 amps, if you can.
[edit] Just saw you have an MK809III. I first read it as MK809II. Not sure where the power LED is on one of those.
Originally posted by big10p View PostWhat actually happens when you plug it in? Anything on screen?
Yes, TV USB isn't good enough for these sticks. However, that's clearly not the issue here with failing to boot, even.
How did you turn off the device the last time it was working? Did you click on the power down icon and wait for it to fully power off? Maybe your ROM has been corrupted. The only thing I can think of doing is flashing a new ROM.
Originally posted by big10p View PostYes, TV USB isn't good enough for these sticks. However, that's clearly not the issue here with failing to boot, even.
There are currently 2502 users online. 1 members and 2501 guests.
