Sx05 Retro Edition V1.2 with video prewviews!
I have a problem, after having brought my box to a friend who has a TV 43 ", Now when it comes to emulation station The screen freeze. To see everything normal, I have to go into KODI, I have to change the resolution to 720 and then reset it to 1080. I start emultion station and the screen is ok.What could be the problem?
Hi Niabi,
I'm trying to write a script to launch games/retroarch directly in Kodi for my addon (IARL) using your build. I've got a script to launch the game working without issue, but when i exit the game/retroarch, the system restarts both Kodi and emulationstation. Is auto-restarting emulationstation on exit of retroarch somehow coded in? Is there a way I can prevent that?
Edit: I found the patch on github that does this, and requested an option maybe to not restart ES?
Thanks for this awesome build!Last edited by zach_morris; 13 August 2017, 04:09.
Hi Niabi,
I'm stuck on the Dreamcast date setup screen, no buttons on the Xbox 360 controller work. Tried to run the reicast-joyconfig.py script on /usr/bin and assigned buttons but nothing changed. Any clues on how to fix it? Thanks!
*UPDATE: Solved it by changing, on /storage/.config/reicast/emu.cfg, the line
evdev_device_id_1 = 5 to
evdev_device_id_1 = 3Last edited by kreator; 12 September 2017, 02:13.
Hi Niabi,
Just a quick thanks for a this build on s905 devices. I hope you keep up the development on this.
Wondering if you able to pull the source code for Drastic NDS emulator from somewhere and get that compiled for s905? This would end my reliance on the Pi3 altogether.
keep up the great work!
cheers
There are currently 3187 users online. 1 members and 3186 guests.
