[ROM] Beelink MX3 II / Mini M8S II Stock & Nano Nexus ROMs
Guest
Guest
Originally posted by zelder View PostIs there any way to install this one without having windows and the usb burning tool?
Originally posted by Magendanz View PostWell, if you can borrow someone's PC or run a Windows emulator, you can create the files needed for an SD card with BootcardMaker. Also, in the link for BootcardMaker, there are Linux/Mac instructions, but they're considerably more complicated.
Thanks. I've borrowed a windows PC. Forgive me for asking, but I download the USB burning tool, burn the img to a usb stick? Do I then use the Update app that came with my stock firmware to install it? And after that has been done I need to download TWRP manager, reboot and then install the file from here? Given that I have m8s 2?
Sorry for many stupid questions. This is a new world for me. Bought the M8S 2 because of the OTA function. Shame that they don't deliver updates through it any more.
Guest
Originally posted by zelder View PostForgive me for asking, but I download the USB burning tool, burn the img to a usb stick? Do I then use the Update app that came with my stock firmware to install it? And after that has been done I need to download TWRP manager, reboot and then install the file from here? Given that I have m8s 2?
Guest
I used the Beelink 111M0 official release to refresh OpenGApps and pull SuperSU. (They removed it from the OEM firmware a while back, and there were some folks who thought it should be optional.) I also updated some vendor DRM libraries to enable video playback in "regular" Netflix. (Unfortunately, the Android TV version of Netflix still has no workaround for units without Level 1 Widevine certification.)
Hi
atm I´m using the official 111M0 ROM on my MiniMX3 II with 2/32G memory.
There are 2 bugs in this ROM :
1. no EXT driver for MicroSDCard (I have libreelec on it) so everytime I boot android without removing SDcard I´ll get a "corrupted SDCard Message" from Android
2. audio problems with dts 5.1
SPMC crashes with raw passtrough and plays withe noise with IEC Passtrough
Kodi is like SPMC
FTMC plays dts 5.1 but if I select an audio file with 5.1 dts - then it is played about 10 % too quick.
Deep purple lead singer sounds as if he has lost 2 urgent things ;-)
Video files with 5.1 dts are played without issues in FTMC and with build in Media Center.
Are these bugs fixed in your Custom ROM ?
Guest
Originally posted by Magendanz View PostSince it's built on the same MiniMX3 II 111M0 OEM firmware, my custom ROM will probably have those same bugs. I'm updating the UI and apps, but not the underlying kernel, drivers, codecs and libraries.
I have already emailed beelink and regged in the forum there, but no answer and forum status pending..
Minix has shown that android dts audio problems can be solved - but paying 3 times more money for a device which is only in wlan different..
So I hoped to find a custom rom without these bugs.
Until then I can still boot the librelec Version of kodi without problems described above.
Guest
Major new release today. Please let me know if you spot any issues.
Changelog (20170523):- New Nexus logo splash and device name of "Nexus MX3 II".
- Added kernel modules (device drivers) for Sony PS3 and Dragonrise USB HID game controllers.
- Updated for latest Open GApps build (20170523).
- Updated to TWRP Recovery 3.1.1-0.
- Resolved issues with Google Keyboard, allowing it to replace AOSP keyboard as default IME.
- Added SELinux security contexts during sparse file system creation.
Guest
Changelog (20170606):- Enabled multi-user support.
- Added kernel module for many USB Bluetooth dongles (btusb.ko).
- Reverted to AOSP keyboard, since Gboard just doesn't have the necessary D-pad navigation support.
- Removed several libraries that are no longer required.
- Updated for latest Beelink firmware OTA update (112M0) and Open GApps build (20170606).
#60.1Guest commented01 August 2017, 12:41Editing a commentSo, did you see this? http://freaktab.com/forum/tv-player-...999#post659999
There are currently 3671 users online. 0 members and 3671 guests.
