[ROM] Beelink MX3 II / Mini M8S II Stock & Nano Nexus ROMs
Nano version + Simply Launcher, working good on SCISHION V88 PRO TV Box Amlogic S905X 1/8 GB
on/off remote not work.
Thankyou!
PD, On week later and remove this firmware, impossible normal use, more lags and frezzes, in Amazon prime video for example.Last edited by clydde; 20 January 2018, 01:30.
Originally posted by Magendanz View PostUnfortunately, the IR code for power-up from shutdown is hardcoded into the bootloader. (It's actually only pretending to be shut down. If there's power applied via power connector or USB OTG, the bootloader is running.) For this reason, you can update the remote.conf to substitute another remote for all operations except wake from shutdown/standby.
Originally posted by Magendanz View PostTo download the QCA9377 wireless chipset updater, click here. Just install this in TWRP over any variant of the latest MiniM8S II Nexus ROMs. When done, you should have an updated kernel and drivers for the Qualcomm QCA9377 chipset. (Note that this is targeted for only the rv109 incremental build. While it might work on other builds, you override the build assertions in the install script at your own risk.)
Originally posted by rahzel View PostGuest, the TX7 7.1.2 firmware is working so far with my M8S Mini II without any modifications. Could be a good base firmware for your ROMs. I would love a Nano Nexus ROM based on it.
Here are some points about TX7 firmware:
- No bloatware. Even the logo is standard AMLOGIC S905x and has stock android animation.
- Remote config not required for X96. Power On/off works flawlessly as in stock 6.0.1( no '2' button press bug to power On)
- The ROM is fast, though not as fast as 6.0.1 ( it may require customizations such as reducing the framebuffer and UI resolution)
Can you please give it a try..
Cheers,
Guest Tried this firmware on my X96. Perhaps the fastest firmware I found that runs even better than stock ROM. Thanks!
I replaced the stock remote.conf to regain stock remote functionality, but the power button was still mesed up. So, I went further and replaced Uboot (all the 3 files) using Amlogic customization tool. Power button issue got resolved but 'Nexus' boot logo got messed up this time(see attached pic). It has moved to the right with some weird colours. Do I need to make adjustments to the partitions as well after replacing the bootloader ?
Can you pls. help?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
SO i just wanted to post that this rom works really good on the Libre LaPotatoe SBC board, it is a white SBC board you have to build like a raspberry pi, its has the same form factor as the Pi3 with the 4 USB, single LAN port, HDMI and Micro USB power like a phone.
The stock firmware on the emmc module sucks, and the oreo version on their site is just as bad.
Even though this is a "older" version of Android it runs on this board REALLY good! plays games well, its fast has a power button and an apps kill button on the bottom menu strip
SO if you have one of these ide recommend this rom
There are currently 2355 users online. 0 members and 2355 guests.
