MX3-G2 2/32gb help!
Hi, can you give more details on the hardware ? is it S802 or something else ? is it 2GB ram or else ? was it running 5.1 or 6.0 android ? please be more specific and we can find the suitable firmware for your device.
you need to hard reset your device to fix the boot loop. hard resetting differs from box to box, check youtube for some advice .
Originally posted by ghostdog View PostHi, can you give more details on the hardware ? is it S802 or something else ? is it 2GB ram or else ? was it running 5.1 or 6.0 android ? please be more specific and we can find the suitable firmware for your device.
That is easy , just grab any firmware for any S912 , 2 GB and you will be alright , this forum is full of them , any T95z , T95U or any T95 firmware will work, the only thing is wifi drivers , with a bit of luck they will work , otherwise look for an S912 , 2GB firmware that has the same wifi chipset as MX3 .
You can flash the firmware using SD card or better , USB burner tool.
Good luck.
Originally posted by ghostdog View PostThat is easy , just grab any firmware for any S912 , 2 GB and you will be alright , this forum is full of them , any T95z , T95U or any T95 firmware will work, the only thing is wifi drivers , with a bit of luck they will work , otherwise look for an S912 , 2GB firmware that has the same wifi chipset as MX3 .
Good luck.
There are currently 2744 users online. 0 members and 2744 guests.
