I have successfully built a ROM with AML customization tool for my A95X s905x, my question is the Rom works flawless reboot and everything works. my only problem is if i do a factory reset from the settings menu, the box will brick it self. does anyone know how I can fix this problem?
[HELP] A95X s905x and factory reset?
Hey guys,
I have successfully built a ROM with AML customization tool for my A95X s905x, my question is the Rom works flawless reboot and everything works. my only problem is if i do a factory reset from the settings menu, the box will brick it self. does anyone know how I can fix this problem?Tags: None
Originally posted by prahjister View PostDownload twrp. Unpack to level 1 rename TWRP recovery to PARTITION and replace existing and pack back. See if it helps
Thanks for the input.
When I do a factory reset it just boot loops to the recovery, either TWRP or stock.. and the only way to fix it is to reflash the firmware with USB flash tool. it dose the same thing the nexbox does if you don't change the UBOOT.USB files in level1 after rebuilding the rom.
Strange thing is the box will not go into recovery with toothpick when on a custom made rom.. if I flash stock rom it will go to recovery with toothpick.
thanks for taking your time and helping me with this it very much appreciated
There are currently 1992 users online. 1 members and 1991 guests.
