NEXSMART D32 (1GB+8GB) Official Android 6 firmware
bluesmanuk they hear my prayers. I already tested and finaly solve the youtube problem. And work very smooth. In this moment the only the thing is missing is hdmi passthrough.
By the way i tried this remote control for smartphone from ugoos download center and works very well. This app make the connection with the app eMediacentre.
Tools and guides.
https://mega.nz/#!KUAjDAqJ!VUgqLHP-w...c8C9GQtEjTDtDULast edited by Zebraino; 25 February 2017, 15:56.Beelink X2 and Nexsmart D32 for now!!!
From my testing, I would say that it's a thumbs up for this firmware, with just 3 modifications being required to make it satisfy most needs.
1. The USB connection option is missing in settings. I used a settings apk from another firmware to confirm that it will work, so just needs the option adding.
2. There is no HDMI audio passthrough option. I did find a way to turn the feature on but when playing AC3 all I get was noise. I know that it is present in the latest HPH RK3229 firmware, so must be potential to enable it.
3. Make TVMC a completely clean build with no custom skin and only the default repositories. There is an app provided for those that wish to add the addons in one go, so no need for them to be present in the default TVMC build and removing them will save a little space on the image size.
Just goes to show that a cheap box with cheap components can do a perfectly adequate job with the right firmware and credit has also to go to the vendors for providing an upgrade path from Lollipop to Marshmallow.
Hello,
bluesmanuk Look forward to you posting your experiences
To include Google Widevine modular DRM
CordiallyDOLAMEE D5, H96 S905, H96 Pro S912
bluesmanuk its really surprising to see what a good job they did and that at least one chinese tvbox manufacturer tries to listen to customers.
are you planning to produce a mod of this firmware or are you happy enough with the stock one for now?
Originally posted by SuperS View Postbluesmanuk its really surprising to see what a good job they did and that at least one chinese tvbox manufacturer tries to listen to customers.
Yes I am working on modding it to give videwine support and HD audio passthrough but I'm not yet there as there are some bugs, so a case of watch this space.
Hello everyone, As nobody answered me I give the solution in the firmware dolamee D5 1 g / 8 g Which included Google Widevine firmware for the modular DRM
http://f1riv.freeboxos.fr/share/Km0FO4uW...vineOK.zip
cordiallyLast edited by bluesmanuk; 09 March 2017, 15:30. Reason: Translated to English. https://translate.google.com/DOLAMEE D5, H96 S905, H96 Pro S912
There are currently 2274 users online. 1 members and 2273 guests.
