This one turned up i plugged it in and started to use it only to find that it was sluggish and some of the apps were crashing, on further investigation I noticed the resource monitor (stock) was running at 80% i figured this to be quite high since there was nothing running. I check my other box only to find that that was running at 40%.
I checked the memory and sure enough the first box was reporting 1.8gb ram free whist the newbox was reporting 800mb, I contacted Gearbest only to be told this is normal as the system takes up some of the memory. I explained to them that I had 2 identical boxes side by side (running the same stock rom) and so they should be identical with no apps running.
They dont accept that this is a quality issue and have offered me a small partial credit or I can send the box back at my expense to get a refund.
What I really want is the box that I bought to work like the first one, Just wondering if there a setting or something I can do to resolve this issue as I dont want to send the box back but also its not much use to me with only 800mb ram free on start up.
I have enclosed some screen shots, Thanks in advance for any help, advice.
