Brand: Beelink Model: AP42 Type: Mini PC System: Windows 10 Processor: Apollo Lake N4200 CPU: Intel Pentium N4200 Core: Quad Core GPU: Intel HD Graphic RAM: 4G RAM Type: DDR3 ROM: 64G |
Decoder Format: H.264,H.265 Video format: 1080P,4K,H.264,H.265,MPEG1,MPEG2,MPEG4,RM,WMV Audio format: AAC,AC3,ACC,DDP,DTS,FLAC,MP3,OGG,RM,TrueHD,WAV,WMA Photo Format: BMP,GIF,JPEG,JPG,PNG Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: 3.5mm Audio,DC Power Port,HDMI,LAN,Reset Port,SD Card Slot,USB3.0 Language: Multi-language HDMI Version: 1.4 Other Functions: ISO Files External Subtitle Supported: Yes HDMI Function: HDCP Power Consumption: 18W RJ45 Port Speed: 1000M |
System Bit: 64Bit WiFi Chip: 802.ac |
Power Type: External Power Adapter Mode |
Remote Controller Battery: 2 x AAA batteries |
Product weight: 0.3370 kg Package weight: 0.7700 kg Product size (L x W x H): 11.90 x 11.90 x 2.00 cm / 4.69 x 4.69 x 0.79 inches Package size (L x W x H): 13.65 x 12.90 x 8.55 cm / 5.37 x 5.08 x 3.37 inches |
Package Contents: 1 x Beelink AP42 Mini PC, 1 x Power Adapter, 1 x English User Manual |
Beelink AP42 Mini PC 4/64GB
64bit Intel Pentium N4200 CPU Supporting BT 4.0 Win10 System
GearbestLast edited by trebor; 21 March 2017, 01:08.Tags: None
coupon: GBAP42
179.99$
Coupon is ready!
#1 Gearbest TV Box & Mini PC Page
#2 Flash Deals Flash Deals
#3Coupons Coupons, Coupons and More Coupons
Today we will have a look at the Beelink Intel AP42, thanks to Gearbest and DHL.
AP42, Mini PC, Windows 10, Apollo Lake N4200
Intel Pentium N4200, Quad Core.
Intel HD Graphic
4G DDR3, ROM: 64G
2.4/5G AC WiFi, Bluetooth 4.0
Beelink AP42 Mini PC, 1 x Power Adapter, [email protected]
1 x English User Manual, 1 x Mounting Bracket, 2 x HDMI Cables
Whats in the Box
GearbestLast edited by trebor; 21 March 2017, 01:09.
Bit of a look inside of the Beelink AP42
Underneath
Top View
WiFi Chip
Msata Slot and eMMC
More Ports
Heatsink Back and End view
Now for the first run and we see how it goes.
Proper Windows 10 start asks Country/Region, Language, Keyboard layout, and TIme Zone.
Then it asks for Windows Product Key
Click on Do this later and continue on with Setup as the activation will automatically happen in backround.
There is no need to Enter Product key.
Then Continue on with the Setup, all easy and then you will be in Windows 10 Version 1607 14393.576
Then I Checked for Update as there was a update today
Wifi Good and download easy and update equally as easy, now on 1607 14393.969.Last edited by trebor; 21 March 2017, 04:34.
Metal Box as well it's a Beefy device for sure...
Ok a few Test and Benchmarks and Info.
Overall a good little unit, for its size and performance....
Gearbest
I received my AP42 recently, but couldn't get any of the Linux installation CDs (such as Ubuntu 16.10, 16.04, OpenSUSE) to boot. They all freeze with black screen with a cursor at the top left corner. It seems it gets stuck at GRUB. I tried playing with BIOS settings with no success (there are very few settings in the menu). Beelink website has nothing but product page for AP42/34.
Any idea?
I spent a bit more time to figure out why none of the Linux installation CDs I tried fail to boot up.
It seems GRUB2 fails to start no matter what. I tried creating a CD and USB stick that just have GRUB2 (both 64 bit EFI and 32 bit EFI. Verified to work on other machine) . They all freeze with a non-blinking cursor at the top left corner of the screen.
Windows and FreeBSD installation disks boot up fine, so I believe it's an issue between GRUB2 and AP42. Hopefully Beelink will release a BIOS fix or GRUB2 will be fixed, but at this point don't expect Linux to run. They pretty much all rely on GRUB2 for startup and even the latest GRUB2 doesn't work.
There are currently 3187 users online. 0 members and 3187 guests.
