Beelink AP42 Mini PC 4/64GB
I don't have this device, so can't try.
In BIOS, under security tab(if available), is secure boot enabled? If so, try disabling it. Though significant vulnerabilities exist with secure boot disabled. Secure boot.
Originally posted by sgargiulo327 View Posttry this link there may be a hint http://www.cnx-software.com/2017/02/...o-lake-laptop/
The BIOS version on my AP42 is AB1 0.12 which is same as the one trebor is referring to.
Guest
BTW, I ran PCMark 8 Home and Work benchmarks and compared them to my Z83 II, which is based on the CherryTrail x5-Z8350 SoC. Here are the results:
PCMark 8 Home Conventional: Z83 II - 1140, AP42 - 1585 (+39%)
PCMark 8 Work Conventional: Z83 II - 1446, AP42 - 2008 (+39%)
PCMark 8 Home Accelerated: Z83 II - 1434, AP42 - 1692 (+18%)
PCMark 8 Work Accelerated: Z83 II - 1166, AP42 - 2741 (+135%)
So, you can see a pretty significant performance improvement with the Apollo Lake N4200 chipset (although some improvements are certainly due to the additional DRAM).
BTW, I tried to run the much faster WinSAT formal benchmark, but it failed on the AP42 because of a BIOS issue.Last edited by Guest; 04 April 2017, 01:54.
@Magendanz.
Could you check how many memory channels that device use? I would really like to see CPU-Z memory page.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Yes and no.
I can see there picture of PCB with just two ELPIDA FA232A2MA chips (32 bit data bus each). That tells me there is only 64 bit memory bus. I mean "only" but for N4200 it is quite enough even if it can support even 128 bit bus width.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Guest
Thanks.
It seems that CPU-Z can't properly identify such memory.
Code:DMI Memory Device designation ChannelA-DIMM0 ormat DIMM ype unknown otal width 16 bits ata width 16 bits size 2048 MBytes DMI Memory Device designation ChannelA-DIMM1 format DIMM type unknown total width 16 bits data width 16 bits size 2048 MBytes
Guest
Yeah, I think this is what's causing a problem for WinSAT too. I see this in the log file for the formal WinSAT performance assessment (with funky characters after Part_Number that don't show when I paste them into this thread):
Code:61305640 (11072) - common\loadrecentresults.cpp:0789: We could not find a match for HARDWAREID_MEM_DIMMS 61305640 (11072) - common\loadrecentresults.cpp:0791: SystemBoardInfo_1[0]: Manufacturer:0000, Part_Number: , Form_Factor:9 Type:24 Type_Detail:128 61305640 (11072) - common\loadrecentresults.cpp:0791: SystemBoardInfo_1[1]: Manufacturer:0000, Part_Number: , Form_Factor:9 Type:24 Type_Detail:128 61305640 (11072) - common\loadrecentresults.cpp:0794: SystemBoardInfo_1[0]: Manufacturer:0000, Part_Number:, Form_Factor:9 Type:24 Type_Detail:128 61305640 (11072) - common\loadrecentresults.cpp:0794: SystemBoardInfo_1[1]: Manufacturer:0000, Part_Number:, Form_Factor:9 Type:24 Type_Detail:128 61305656 (11072) - exe\datastore.cpp:1090: No files with exact match in the datastore 61305656 (11072) - exe\datastore.cpp:1151: DEBUG::We could not find a match for Assessment DATASTORE_MEM
Code:61305671 (11072) - exe\main.cpp:4076: ERROR: 0X80004005 DataStore::BuildFormalFromMostRecentPartialAssessments failed. 61305671 (11072) - exe\main.cpp:4847: ERROR: Unable to save validated results. 61305687 (11072) - exe\processwinsaterror.cpp:0298: Unspecified error 46 occurred.
Guest
While I couldn't get WinSAT to save the formal composite assessment because of the problem above, I was still able to compare the raw results with the Z83 II. The performance improvements are significant:
Given that read performance for eMMC is roughly three times as fast, it's no wonder to me now why it feels so much more responsive.Last edited by Guest; 07 April 2017, 09:14.
There are currently 3089 users online. 0 members and 3089 guests.
