[ROM] Khadas Vim SCV2-ATV (Android TV)
    AP6212 according to Gearbest.
      ha that is why... i dint add that driver!!!
        I will fix it and upload SCV1B...
          Can you guys try this rom? both Pro and Non Pro... i cant now on the Pro and i dont have the Non pro to try it!
            Downloading now.
            WiFi addition for 2/8 unit only diff here?
              yes, but i may have broken on the the 2/16 one... you never know, since i cant really test now!
                2/16 appears all well here.
                  2/16 Wifi seems to be OK here too. Same for Bluetooth. So nothing 6255 broken.
                  Vim 2/8 WiFi module info from Wesion.
                    Thks now will wait for the test result on 2/8 and if all ok i update the 1ยบ post with it
                      Did some initial testing with the t1 version on the 2/8(non pro) and the WiFi seems to work fine now:-)
                      Nice Work, Thanks !!!!
                        Ok thks for the tests, im going to update the 1ยบ post with SCV1B
                          SCV1B download is failing MD5. 4 attempts, two computers, all same result. Can anyone confirm MD5 pass or fail?
                            Ups sorry Riscy... i forgot to change the MD5 from the A to the B... fixed now!
                              No worries, I should have noticed that.
