[ROM] Khadas Vim SCV2-ATV (Android TV)
Originally posted by rodrj View PostPlease help me. I can not install any other apps from the playstore. installed apps do not update.
"Go to settings -> storage and reset -> factory data reset, when format finished VIM will reboot, on first boot choose setup wizard and set wifi and google account. After this you will get working google play. I use latest SCV2-ATV and now I have full working ATV with Kodi and other apps."
Works
Originally posted by AFQuintans View Post
happened the same and gave this tip in the forum khadas
Works
Hi to you all and many thanks to SC for his work!
I have a question, will there be a newer version of this rom, it doesn't matter if it's Android 6 or 7, as long as it works good.
I am on latest stock nougat image, and it was more or less fine until yesterday when Android system ui started closing once again, had same problem on nougat images before, i couldn't do nothing until i rebooted.
I do believe it is something that is easily solvable, especially because the rom is rooted, i would do it myself if i knew how.
I did write this on Khadas forum before, and i did believe this was solved, but it looks like it isn't.
I have reason to believe, that this bug has something to do with language settings, it would always start to happen when i changed language and usb keyboard settings to my native language.
If anyone can confirm stability of previous SC roms, are they ok to flash?
I know you do this in your spare time, and you don't earn money from this, that is the reason why i am asking.
Sent from my Redmi Note 4
sorry for asking about the installation instruction, but I installed a longer time ago the DUAL-OS Image from the original side with Android nougat (Andorid 7) and Ubuntu 16.04 and would love to keep a double-System. I haven't updated or replaced the Uboot image and not sure if I need another one or not.
The reason why I wanna change something is because the System crashes very often. I use a 5V 3000mA Model, but sometimes it crashes when it is opening youtube, sometimes when it boots and sometimes when you open the chrome-browser.
It's strange, when I connect it on my PC with USB3.0 the system runs better, but still sometimes crashes. I changed the Power-Supply already, but it seems that there are some problmes with the voltage-range. I also thought about to give higher voltage on the direct DC-Supply-Connector. On the Website there is the information 5,2V DC-MAX: http://docs.khadas.com/basics/ExtraPowerInput/
Does it make a difference to an extra Voltage via USB?
Any experiences with the Voltage-Problems?
Can not download the file hosted in the http://freaktab.org/56b0b900348e50fb
It always says : "Error: Too many concurrent download requests."
Can you upload it somewhere else, Mega maybe?
Thank you
Originally posted by BUKULAWAS View PostCan not download the file hosted in the http://freaktab.org/56b0b900348e50fb
Thank you
There are currently 1538 users online. 1 members and 1537 guests.
