The only problem that I have it's that the google play store dosn't search in the app repository so I need to download the apps from internet. It search only the games app (and not all of them). It seems that the google play store is non working good.I tried re-flashing your ROM many more time but the situation is always the same. Is there any way the have a standard google play store? thanks
[ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) SCV2-ATV (Android TV)
hello superceleron, I installed the ROM. It's very good. I have also re-flashed the original last ROM .img with the usb burning tool to se the new ROM but I like more yours so I did a new flash of your ROM.
Originally posted by cappoccia View Posthello superceleron, I installed the ROM. It's very good. I have also re-flashed the original last ROM .img with the usb burning tool to se the new ROM but I like more yours so I did a new flash of your ROM.
the ROM is a androidtv version, therefore it doesn't have all the apps, only the androidtv compatible... you could try ohter stores like apptoide!!
Originally posted by che33 View Posthello,
i cant flash it in to my mecool pro.
I go to recovery mode and want install,but there comes the information:meta-inf/com/google/android/update-binary' konnte in der zip nicht gefunden werden
Hi, try this rom, it's ok, but I want to go back to the previous original version. When I do this through the USB Burning Tool I get an error of 3%
[18:09:12 579] [Global] [Inf] - Update HUB3-19
[18:09:12 579] [HUB3-19] [Inf] - Update device path
[18:09:12 614] [HUB3-2] [Inf] - Device is removed
[18:09:22 662] [HUB3-2] [Inf] - Detect Device connect timeout
[18:09:22 662] [HUB3-2] [Inf] - Close device handle 0x00000a48
[18:09:22 712] [HUB3-2] [Err] - Device path is null or device connect status is error
[18:09:22 727] [HUB3-2] [Err] - [0x10302001] Romcode / Chuyển trạng thái / Check connect / Enum thiết bị lỗi
How can I get back to the original version?
Great superceleron, u did a very good job!
I put your rom on my Yokatv kb2 pro...and it was a really flawless installation.
Also the frame rate on games become better than the original (and way better when I upgraded to Nougat)...
U have my congratulations!!!!
ÂTronsmart MK908II RK3188(non-T)
Hi superceleron...
Plz i would like to ask you something...
On the SCV1 version of your Rom ( [ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) Superceleron V1 Rom)... you said that:- Custom Kernel, faster emmc/ram management and cooler cpu.
So, in the nem SCV2 version ( [ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) SCV2-ATV (Android TV))....
you did that too? (or it's an upgrade of the v1, so this feature was already there).
Thanks a lot.. i'm having a lot of fun with it!
And plz forgive my terrible english (I'm from Brazil)!!
There are currently 2686 users online. 0 members and 2686 guests.
