[ROM] Mecool BB2 Pro(DDR4) / Vorke Z1(DDR4) SCV2-ATV (Android TV)
Ok i view some foruns and some videos, but for this box i didn't know what pins i have to short. Did you know? Somo boxes are for example 5 and 6 pins, but for this box i didn't find the answer.
Thank you for the help superceleron
Originally posted by firewel View PostOk i view some foruns and some videos, but for this box i didn't know what pins i have to short. Did you know? Somo boxes are for example 5 and 6 pins, but for this box i didn't find the answer.
But if you do find it please post in our forum for pin locations Thread so other users can use the info. http://freaktab.com/forum/main-categ...short-locationMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
it's pin 5/6. Works greatbut i only can install superceleron room. Stock firmware from mecool its not possible but its better that away
Thank you
Installed (finally) the rom this morning and now configuring it.
Xposed is a welcome addition. Thank you very much.
For new flashers (android that is) like me:
YOU WILL NOT NEED POWER CONNECTION TO FLASH ROM.
Note: For Windows 10 Make sure the USB burning tool is installed using the Windows 8 compatibility. Right click on the "Setup v2.0.x..." file and select the 'Troubleshoot compatibility' option and follow the instructions to make sure it is Windows 8 compatible and save the settings. This will help with having the USB burning tool recognize the box.
1. Run USB Burning Tool. To change to English select the second menu item from left at top and in the drop down you will be able to select 'English'.
2. Select the 'File' menu at top left of program window and select 'Import image'
3. Find the image file you unzipped/decompressed. For this example the file is 'SC-V1-BB2Pro-VorkeZ1.img'
4. Connect one end of the two sided male-to-male USB to PC usb port,
5. Hold down reset button by using a paperclip end in the small hole is on the back of the box near the input ports and then plug the other end of the USB cord into the box, release reset button (paperclip end)
6. The USB Burning Tool should recognize the box and and show it is connected in the top box area (mine displayed as Hub 2...) once connection is recognized/confirmed
7. Click on "Start" button on burning tool to begin flashing, Should complete in under 10 minutes.
8. When the program displays the flash is completed successfully, click "Stop" button on burning tool, disconnect USB from box.
9. Now you can connect the box to the TV hdmi, and plug in the power. Wait about 10 minutes for it to boot/startup and then you will be able to configure the box to your needs.
(adaptation of instructions provided)
I had messed up my device attempting to add SU to the stock rom in the first place. I could not recover the stock rom to flash to the device, however after using these instructions I was able flash this rom and get it to start up.
To do: establish SU, configure Play Store, install Xposed add ons, and other programs.
@superceleron, Thanks for your latest rom. I only have one problem. I cannot seem to add a VPN for the android box that is pptp version, where you give the location, and then username and password for the vpn. This way you can add multiple location for the same vpn provider. Any help on this would be very appreciated. Great job on the rom
Originally posted by tharunam View Post@superceleron, Thanks for your latest rom. I only have one problem. I cannot seem to add a VPN for the android box that is pptp version, where you give the location, and then username and password for the vpn. This way you can add multiple location for the same vpn provider. Any help on this would be very appreciated. Great job on the rom
Since i dont use VPN i never check it.
But i will see if i can do something about it, but not promising nothing since him really full of work this days!
Well i need to check it, but i think its broken on the ATV build.
Thanks.
How do you get to move an icon from multiple apk;s to the main screen for just one apk that you use more often like kodi.
Originally posted by Figaro1991 View PostInstalled (finally) the rom this morning and now configuring it.
Can i flash this with Burn_Card_Maker like this method: https://www.youtube.com/watch?v=YHRQ...92957781971768
Sorry that i cannot good speak.
There are currently 2521 users online. 0 members and 2521 guests.
