Z69 Plus TV Box Amlogic 912 2/16GB 3/32GB 3/64GB Dual Wifi Fast Lan, BT 4.1,
    Originally posted by Z69plus View Post
    Thank you.
    It seems Shortcut Master is not compatible with Top TV launcher 2 or? I created a shutdown shortcut but i cant see it in the desktop.
    On the contrary. It works fine. But I use another launcher for a lot of time. As I remember, I placed a shortcut of the shortcut master, or smth like that and then renamed it. I don't remember...
      Click image for larger version  Name:	Screenshot_20180828-065454.png Views:	1 Size:	854.8 KB ID:	742162Click image for larger version  Name:	Screenshot_20180828-063836.png Views:	1 Size:	182.1 KB ID:	742159Click image for larger version  Name:	Screenshot_20180828-063846.png Views:	1 Size:	872.1 KB ID:	742160 Click image for larger version
ID:	742997 KHADAS VIM2 on Z69 Plus.
        I have problem with z69plus 3/32Gb box. It crashed and when i flash stock rom again ( tried with burning tool and with card maker.. ) the message "media launcher isn't responding" is diplayed.
        I can get into recovery mode.. I can install TWRP and it seams it is working fine..
        I tried different images for other look a like devices.
        The only image that i was able to find for this divace is z69Plus_3G_7.1_0824.img
        Can someone give me some older version ?
        Any advice ? I'm stuck here :-/
        Tried to change original heatsink with better one and did not help :-/
        Is it possible that charger could be the problem? I measured good voltage on it but who knows.. From one hand it is strange to me that all firmware I tried gets to some kind of freeze at the start, but from the other hand if there is some hardware problem how twrp works? I even tried installing libreelec - no luck with that ider..
        Click image for larger version  Name:	poruka.jpg Views:	1 Size:	53.7 KB ID:	769405
          Originally posted by juricom View Post
          Try to brush another firmware!
          https://4pda.ru/forum/index.php?show...#entry76547145
            Originally posted by lyubodelev View Post
            Freezing again.. :-/ Intro video works, but after that no luck again ..
              try this Ron {ROM} PoisonATV V4.8 S912
                Originally posted by antonio6o6 View Post
                https://mega.nz/#F!NhxCkQLb!YU0W6OZqxi20V8tqZpsdeQ
                The file was removed!
                  yes the files was remove
                    PoisonATV_V4.9_S912.Mod 2 Final Video improvement
                      SlimBox v. 8.3.2 Android TV 9
                      https://mega.nz/file/FZgwVaSQ#GK3wQy...bsZx1ffo_dLuas
                        I have the T95k Pro (multi-color case) with 2/16Gb.
                        Could someone please give me a working link for a stable ROM (zip or img) for this S912 box please?
                        All the link in the first page and the last page are no longer valid.
                        Thank you all.
