Model: Z69 Plus Type: TV Box System: Android 6.0.1 Processor: Amlogic S912 CPU: ARM Cortex-A53 Core: 2.0GHz,Octa Core GPU: ARM Mali-T820MP3 RAM: 2G or 3GB RAM Type: DDR3 ROM: 16G or 32GB |
Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS,VO B,WMV Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA Photo Format: BMP,GIF,JPEG,TIFF Support 5.1 Surround Sound Output: Yes |
Bluetooth: Bluetooth 4.1 Power Supply: Charge Adapter Interface: HDMI Language: Multi-language HDMI Version: 2.0 Other Functions: 3D Games,3D Video,DLNA,Miracast,NTSC External Subtitle Supported: No Power Consumption: 3 - 7W RJ45 Port Speed: 10 / 100M |
System Bit: 64Bit KODI Pre-installed: Yes |
Power Type: External Power Adapter Mode |
Product weight: 0.2000 kg Package weight: 0.4200 kg Product size (L x W x H): 7.50 x 8.00 x 2.60 cm / 2.95 x 3.15 x 1.02 inches Package size (L x W x H): 15.00 x 15.00 x 5.00 cm / 5.91 x 5.91 x 1.97 inches |
Package Contents: 1 x TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x User Manual |
Z69 Plus TV Box Amlogic 912 2/16GB 3/32GB 3/64GB Dual Wifi Fast Lan, BT 4.1,
Amlogic S912 Octa-core ARM Cortex-A53 64-bit CPU Android
GearbestTags: None
i have the 3gb version.
it has quite a bit of lag, and i cannot get most kodi addons to work.
they install, but projectfreetv, for example, doesnt show any folders. most others do as well. only openload movies and 1channel fix work at the moment.
i replaced the stock launcher with HAL, wich made it a bit more usable. all apps install as phone apps, as opposed to tv or tablet apps, its quite annoying really.
honestly i am rather disapointed by it, i would not recommend it to anyone until they release some updates for it, or someone makes a custom rom for it.
Today we can have a close look at the Z69 Plus TV Box Amlogic 912 3/64GB Dual Wifi Fast Lan, BT 4.1,
Thanks to Gearbest for the show and tell.
The Box
What's in the Box
Ports
Some Venting
Remove the Lid, not much to see, reset button and no hole, top pops of easy no screws
Out with the PCB, weight block as heat sink could be good.
Lets have a look at what this one has to offer
Must says temps are good Max 65c +/- on testing, Mid to Hi 40c idle, testing YT 2 hours 60c
Google setup and connection all good, both WiFi and Ethernet very good
Zips along pretty good,so far, installing of apps all good and quick must have good ram.
Has Root, No upper or Lower Bars
Like what I am seeing.
On to the Show and tell.
UI Installed Apps and system Information 6-frames
Root
WiFi and Ethernet
DRM: L3
Ram and Storage Truth:
CPU-Z: 3 frames
Geekbench CPU: More > http://browser.geekbench.com/v4/cpu/5551017
Geekbench Compute
Antutu: looking ok
A1 SDbench: Good speed
AIDA64: 7~ frames
Not to shabby i find working very well
Like other Popular Units seen, Temps, Wifi/ethernet good Performance all pretty good.
One to keep an eye on.
Think the earlier lot were suffering from Bodge Software.
Thanks Gearbest
Problem solved, but on this box there are several more problems: lack of status and navigation bars; changing the launcher; availability of electricity in USB ports after shutting down; problems with overheating. I tried turning the box upside down and place a cooler on its new roof - the result was a decrease of about 15 degrees in the temperature!
Originally posted by DiegoDNL View Post, install the apk "set orientation".
The launcher is "Top TvLauncher 2". I used "Shortcut Master" apk to be able to open "Settings/Common Settings"... If you experience some difficulties, write to me.
About the fix of the screen, I use "Orientation Control Pro" apk.
Best wishes!
There are currently 2785 users online. 0 members and 2785 guests.
