****And if you want and ask information please do not say i have a H96PRO+ ****
[info] alfawise H96PRO+/4k ultra H96PRO+
Hello all. Before you want to buy/flash a ROM I want to inform you about this two device's. The Alfawise H96PRO+ and the 4k ultra H96PRO+ . There are slightly differents between the two that you must aware of. Both the devices are named H96PRO+ but inside the device are some details that are different. The EMMC is definitely different . And some other small stuff. As you can see the 4k H96PRO+ had two usb ports on the board not 4. Both device's has there good and bad moments and we can not say what device is better. So that said. You can see now that you must be aware of flashing the 4K H96PRO+ with a Alfawise ROM. I will inform you here when i got more information about this two device's.
****And if you want and ask information please do not say i have a H96PRO+ ****You may only view thumbnails in this gallery. This gallery has 4 photos.4 PhotosTags: None
Originally posted by ReaperMan View PostJust to add to the general confusion about these boxes. At least three generic H96 Pro+ boxes manufactured before Dec. 2016 had the two hidden USB ports.
I did not check all of the boxes.
Reap
This is my PCB. Yesterday I cut the hidden USB and it's working. But I still confusing. I see that wifi module it's 8223A and I just update with firmware 9337, and, also, it's working.
What firmware it's the best for this mbox?You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by adytzu View PostThis is my PCB. Yesterday I cut the hidden USB and it's working. But I still confusing. I see that wifi module it's 8223A and I just update with firmware 9337, and, also, it's working.
Hi vitin2000! Try this...for windows: http://www.cnx-software.com/2016/11/...ogic-tv-boxes/
I recommend to rename img file in "update.img"
You can download img file from here:
mega:#F!TVtSEZpJ!7JIKzxWWhR-8S7kb3pTElw!OclCEaTY
Many thanks to wwmoggy
Originally posted by adytzu View PostHi vitin2000! Try this...for windows: http://www.cnx-software.com/2016/11/...ogic-tv-boxes/
Originally posted by adytzuHi vitin2000! Try this...for windows: http://www.cnx-software.com/2016/11/...ogic-tv-boxes/
Enviado desde mi SM-G950U mediante Tapatalk
Guest
Reap
You use this firmware? mega:#F!d1tHVZgA!Qc0mAom7FBHT9HDv3rGtGQ
How it's your device after firmware update? Isn't too hot? How working? Some lags, some issue?
Please share your experience!
Cheers,
AdrianLast edited by adytzu; 07 May 2017, 10:59.
There are currently 1483 users online. 2 members and 1481 guests.
