[ROM] Nexbox A95X S905X Android TV "UPDATED"
    I have recently Ported Magendanz ATV To Nexbox A95X
    Link Download
    http://www.mediafire.com/file/oobmp0..._S905X_ATV.img
    Stock Kernel
    Tried to root But failed (FIXED)
    Based On Magendanz Build
    fixed power on/off
    DO NOT FACTORY RESET OR U WILL GET STUCK WITH BLACK SCREEN (Recovery Issue)
    DO NOT BOOT INTO RECOVERY FOR ANY REASON OR YOUR STUCK .... (TRIED TO FIX BUT STUCK IN RECOVERY, WILL WORK ON IT)
    Aptoide TV Store Added
    FIRST BOOT (IMPORTANT)
    -Let it boot till setup screen, it wont let u press enter
    -Restart the box and it will work for remote and keyboard enter
    Many Thanks to Magendanz/Superceleron
    Tested Build With 1/8 a95x version might work for others
    Let me know if any bugs and in the future we hope superceleron can do a custom kernel based on this stock kernel as somehow its linked to the bootloader and the ir remote ... tricky .... well anyways Enjoy
    any idea can it work on s905 box like mini mx 3....
    MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
      No its only for s905x ... I could build one for s905 but will take time ....
          Great Job !!!!!!
          Thank you very much.
          Testing.........
          Do you remove the file explorer ?
          Cant find it .
          Regards
            yes, just install it through playstore ..... im actually uploaded a new build right now that fixes root and recovery ...... ill post later today just heading to an appointment .,.,.. so if u can wait it will be worth it
              Yes, I will wait.
              Thanks.
                Your Rom have the youtube app that plays 4k videos in 4k tv like superceleron rom ?
                And will the play store work normal, means i can search for any 3rd party app, because SC Rom allows only certain app to be installed from play store
                Please advise
                  Please advise
                  Not complete play store, i think its not possible to install 3rd party app.
                    i added aptoide tv store u can install from there
                      new link updated enjoy people
                        i might rebase the android tv based on a different rom .... the remote home key is not working and recovery keeps getting stuck but for now enjoy the rom
                          not able to install complete play store app directly
                            Hi minixfreak , thanks for your work, greatly appreciated
                            Can we get the 4k youtube app link to try it out to install separately, the playstore youtube app only give 1080 max, thanks for your help
                              im working on my new rebuild hope it works better might take a day to complete
