Beelink GT1 Ultimate short pins
Originally posted by calc View Post
You might want to try to see if it is a button to allow sdcard booting. Does your system show anything when you try to boot currently?
Originally posted by [email protected] View Post
I used to be able to update the firmware by pressing this button and having the firmware on a SD card. But, I messed up during an update. That's why I think my only chance is using the pins. There is no video signal coming from the box. The only sign of life is the led. I've tried installing the firmware using the USB tool but the box is not recognized by my computer. That's why I was hoping to use the pin trick and manage to make my computer recognize the android box.
Originally posted by Jhonnie View PostAll the credits go to the user Chomee from the Beelink support forum, that helped me solving the problem. To him a very huge thanks.
First a little retrospective,
So, I was thinking that the brick of my GT1 Ultimate was my mistake, but after my request to Beelink support for the correct ROM I have received exactly the same ROM I have previous flashed.
I did flash the "GT1_311M0.img" from Beelink link, and was this ROM that bricked my GT1 Ultimate. Yes the supposed original ROM from Beelink.
There are two things, or I have done/doing something wrong or the ROM that Beelink is providing have a really some huge problems. I'm not the first owner of a GT1 Ultimate having this issue; you can check the Beelink forum.
After I flash the GT1 Ultimate with this ROM, the box didn't boot anymore and was not recognized by windows when connect to the PC using the USB A to A cable.
Here is a little tutorial to help those with the same problem “DO IT AT YOUR OWN RISK” (Original ROM provide by Beelink didn't work for me).
1 - Open the GT1 Ultimate box. Search on Youtube how to open it, is quite easy.
2 - Download the custom ROM for the GT1 Ultimate here on Freaktab, from the user superceleron and extract the image file from the downloaded ZIP: http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4
3 - Start USB Burning Tool, set language to English.
4 - Load to USB Burning Tool, the .img file you have extracted. USB Burning Tool will check the image and load it.
5 - Set the USB Burning Tool, to Force erase all and remove the check from the Erase bootloader check box.
6 - Press the Start button on USB Burning Tool.
7 - Connect one end of the USB cable to the USB socket on the side of GT1 Ultimate (must be on the side not on the back), and the other end to the PC. At this point windows will not make any sound or USB Burning Tool will detect the GT1 ultimate.
8 - Using some piece of metal short the 2 pins as showed on the attached image (do not short anything else) you will listen a little moan coming from the box and just release the shorted pins (a little touch on the 2 pins will do the trick). At this point you will hear the typical windows sound when a external drive is plugged in, and the USB Burning Tool will show the connected GT1 Ultimate and will start automatically flashing the loaded ROM.
9 - If you get USB Burning Tool error around 2% wait 3 to 5 seconds and just unplug the USB end from the PC and plug it again, USB Burning Tool will restart from where it leftover. Now just wait until USB Burning Tool bar reach the 100%: Burning successfully.
10 - Press the Stop button on USB Burning Tool and unplug the USB cable. And the flash is done.
11 - Go to your TV, connect the HDMI cable to the GT1 Ultimate, connect the power cord and wait for the magic. The flashed ROM takes around 6 minutes on the firs boot, so just wait and go grave a coffee.
12 - Enjoy
After flash this custom ROM, I have done some tests with the GT1 Ultimate, and connected the GT1 Ultimate again to the PC and it works like it should it is automatically detected by windows and USB Burning Tool.
I did flash again the ROM provided by Beelink, since GT1 Ultimate is working has supposed no short pins was required. I have flashed the original ROM 100%: Burning successfully.
On the TV I connect the HDMI cable to the GT1 Ultimate, and power cord, the GT1 Ultimate lights up but nothing happens. The GT1 Ultimate is bricked again.
I connected the GT1 to the PC, and windows do not recognize anymore the box it is bricked again and I must do all the procedure from shorting the pins again and flash again the custom ROM from superceleron.
Resuming, I think there is something wrong with the original ROM since the custom ROM works flawlessly.
Share your experiences.
Regards,
Jhonnie
12 - Enjoy
Regards,
JhonnieIt works!
But when I tries to use original firmware from Beelink (310M0. 311M0, 312M0 or 313M0) I have MAC address 20:00:00:00:00:00 and I cannot connect to network. Fortunately Beelink GT1 Ultimate SCV1-ATV (Android TV) (DDR4) works fine.
So my Beelink is alive!
The Method By Jhonnie Works perfect
Just to addon
I bad flashed and bricked the GT1 ultimate with same symptoms...Just the blue light and nothing else.....was not detected in AMLBurning tool also...SD Card Method Did Not work
Used Johhnie's method to flash SVC ROm
Unplugged Replugged and Flashed Original GT1_313M0.img from Beelink forum for gt1 Ultimate
All works now!!
Thanks everyone and Jhonnie
Jhonnie, You method work once. The tool did recogonize the port but it error out and i have tried shorting it many times and there is no success. I hear the moan sound but nothing happens on the tool and it does not seem to recogonize. Any ideas. By far your method only had got me somewhere and would really appreciate some insight. I have using a screwdrive and placing inbetween the two pin to hear the moan. Please help
Guys, Finally I revived my bee-link GT1. I manually flashed a firmware and bricked it. The HDMI was out. The box was just showing white light. I followed johnny's instrustion to flash firmware via usb burning tool. I did have to short the nands. There is no other alternative. SD magic boot is nothing but pure junk. I had to short it more than like 80 times to get it to work. So its not that simple. Out of the 80 times the windows box recogonizes only 5 times. So thats the odds you need to work with. I got it running. No Thanks to bee-link who did nothing to help. Thanks to all folks who actually posted something their experience that I used to revive my box.
Did you use hammer 2.0 or 2.1? lol
I have to admit that initial curiosity did turn to giving me a good laugh when I expanded the pictures, so if nothing else, you brightened the day little moreLast edited by bluesmanuk; 23 August 2017, 20:17.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
There are currently 1972 users online. 1 members and 1971 guests.
