Sent from my SM-G930W8 using Tapatalk
Beelink GT1 Ultimate short pins
Please post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by mechaone View PostNo JTAG, but as stated in post #7 opening the box and shorting those two pins will work. At least this flashes factory F/W and brings the box back into life til a custom ROM pops up somewhere.
I didn't mention that my board is the latest board and in the photo you sent some posts in front you have empty pins I have a component a chip on there and I tried too .... Your way I hear the sound like bee but nothing I hit reset with the pin sorted I tried with pin sorted and the to put the cable USB to USB then to have the USB connected and then sort the pins all the compinations... I hit refresh nothing with the same machine I flashed the gt1 ultimate and bricked I used the firmware from super Celeron and I didn't check flash the bootloader as the description says and the flash went by the first time 100 successful then I unplugged the box and put the power cord and I have no signal
Thanks for your time and help
Firstly happy new year with health and a lot of flashing...
I'm not sure if you're saying your tv box is still bricked, but we probably have identical boards. I have the A706 variant, there's a chip soldered where the diagram shows to pin short. I had no problems with flashing factory firmware, but lost the game 5 times with Superceleron's ROMs. Hopefully he has some gold for us soon, the factory firmware is very limited to say the least.
I tried even to contact the company and really the mail went to junk... They play stupid.
Originally posted by dionisor View Post
I bricked my GT1 ultimate because I flashed an invalid FW :-(
Reset button doesn't work and I also tried burning tool and SD maker with no results.
My GT1 have SN A706D0 and It's the same like @ekspertmv.
I think that I need to short pins to revive it.
Please help!!!!
Good afternoon. Can anyone have information about which pins need to be short for Beelink GT1 Ultimate (SN B706) to flash it (the process freezes by 7%). The manual for A706 is not suitable, because when these pins are shorted, the device starts to "whistle" and reloads (checked for two B706). Thank you.
Originally posted by Symo View PostGood afternoon. Can anyone have information about which pins need to be short for Beelink GT1 Ultimate (SN B706) to flash it (the process freezes by 7%). The manual for A706 is not suitable, because when these pins are shorted, the device starts to "whistle" and reloads (checked for two B706). Thank you.
First thing you must do is run the usb burn tool with rom loaded, connect the usb male to male and then
sort the pins at the last picture the two down right pins from 8 pin chip.
Originally posted by Gus View Post
Hello Symo,
Thanks for the answer. In my case, the problem was in eMMC (read only). I do not know how to solve it yet...
Hello Symo
if you tried this method then don't know helping you any further but if you spot the prob maybe you're one of many of cheated by Beelink,
check here http://freaktab.com/forum/tv-player-...7-gt1-ultimate.
Hi All!
I hope it'll help someone. Patient: Beelink GT1 Ultimate SN: LPN1 2019 y.
After an unsuccessful trial to flash custom ROM (burn process hanged on 2% with memory error) was not reacting on anything (either usb-cable connection+ USB Burning tool, either boot SD-Card nor just turning on) - only led light 'on' after power plugged in.
Following pin short options from here and on 4PDA (http://4pda.ru/forum/index.php?showt...#entry74886425) didn't help as this version has slightly different components config.
For this version you should short the following pins (after pressing 'Start' in USB Burning Tool):
After that device gets detected normaly and the flash process goes on.
Flashed [ROM] Beelink GT1 Ultimate SN:LPN1 Android (7.1.2) ALVATECH - works just great.
Success to All!
Originally posted by xanaduer View Posthi, all
Ask for help!
Who knows where the short pins of the attached Beelink GT1 Ultimate are? please tell me. My TV Box is bricked.
TVBox: beelink GT1 Ultimate
SN: LPN1
"Beelink GT-LP Ver 1.1" written on the motherboard
Production in 2018.
Thank.
There are currently 3144 users online. 0 members and 3144 guests.
