nexus sdk cx-919
    nexus sdk cx-919
    can somebody make this rom for cx-919 http://www.freaktab.com/showthread.p...ll=1#post79846 please there is strauzoes nexus sdk2 official v1 build for tronsmart t428
    aren't the 919 and 428 similar enough that the rom should flash as-is?
      modules
      i dont know i am not a rom guy but strauzo talks about modules etc i know you can flash 908 kernel or cx-919 kernel but dont know about the modules in system maybe different hdmi chip
        actually it's mentioned in here:
        saying that wifi and BT won't work if you flash.
          i am awhere of bt and wifi but is rest same hardware ?
            i'm sure they'll get a nexus out soon for all the 3188s. when i flashed the official nexus to my cx919 i got pretty much perfect video playback, so they just have to make the tweak in the finless rom and kernal and it should be good to go.
            i get 1080p
              Originally posted by planetmarklar View Post
              i get 1080p
              you mean you are using the 1080p kernel on the cx-919? If so, does it get hot?
                good Q, idk for sure. i'm using strauzo's SDK2 kernal and it let's me do 1080. idk if that means it's scaling or what but i'd assume it would be true 1080 because strauzo put it out there. with finless 4.2.2 i think it would get hot and the NAND would crash but i'll have to test it with a movie tonight. how do you folks check temps?
                  so to be clear you flashed T428 Nexus sdk2 official v1 rom and the kernel contained in that package? and if so, is your wifi and BT working on the cx 919? and lastly, are you running XBMC?
                    i flashed the whole ball of wax. bt/wifi not working. using stock video player
                      ah ok, thanks for the clarification hopefully we get a rom/kernel for ours soon
                        I am running the Nexus rom with strauzo kernel for Mk 908 on my Cx 919, WiFi and Bluetooth are working fine.
                          ^i'll bet money that fixes most of our problems. flashing right meow.
                          Edit: scratch that. Doesn't work well for me. BT does WiFi doesn't, HD video malfunctioned and froze when I hit back.
                            Where's the strauzo kernal for mk908??
                              strauzo kernel for mk908
                              Here it is :
