nexus sdk cx-919
Kernel link not found
Originally posted by clement View Post
Thanks.
Originally posted by planetmarklar View PostHow do you tell? It says I'm at 1080p 60hz. I think it's built into the kernel?
Originally posted by planetmarklar View PostIm using finless kernal from 4.2.2 package and nexus rom and everything is working great.
It would be much appreciated if you could write up a quick step-by-step of how to flash the nexus sdk2.0 ROM in conjunction with the MK908 kernel. I'm pretty sure I know how this is done, but a quick write-up would be helpful as a reference guide.
smithmal
Originally posted by poul50 View Postat my tvset there is an infobutton if i press it the actual resolution and framerate shows and with nexus sdk2 and finless 4.22 kernel its shoving static 720p*60hrz also when playing 1080 movies
smithmal
download: http://www.freaktab.com/showthread.p...Strauzo-Kernel
extract T428 nexus to folder
extract MK908 kernal and place in rockdev/image/ directory of T428
run RKAndroid tool
press Run
change name of folder to "T428 with MK908 kernel" so you don't get anything confused lol
I tried this on my cx-919 yesterday but the wifi & ethernet speeds were low, netflix was garbled, xbmc crashed etc.
Reflashed using Finless 4.2.2 and all is okay now.
Originally posted by planetmarklar View Postdownload: http://www.freak-tab.de/strauzo/T428...icial%20v1.rar
run RKAndroid tool
press Run
Originally posted by gr8nyker View PostI tried this on my cx-919 yesterday but the wifi & ethernet speeds were low, netflix was garbled, xbmc crashed etc.
There are currently 6799 users online. 0 members and 6799 guests.
