https://mega.nz/#!QdsgxKxC!3ttYKZl7c...YSjoKbw5sYunhY
M96X MAX 4K HDR VP9 TV BOX Android 6.0 Amlogic S905X 2G/16G 802.11b/g/n LAN KODI Bluetooth
Originally posted by demonpt View PostModel: M96X
Type: TV Box
System: Android 7.1
Processor: S905X
CPU: ARM Cortex-A53
Core: Quad Core
GPU: Mali-450
RAM: 2G RAM
RAM Type: DDR3
ROM: 8G ROM
Max. Extended Capacity: 32G
TV Box Features: 5.1 Surround Sound Output
Let's have a look at this a M96X MAX 4K HDR VP9 TV BOX Android 6.0 Amlogic S905X 2G/16G 802.11b/g/n LAN KODI Bluetooth
This one has Android 7.1 and needs a bit of an update about 2 months the firmware appears to be...
Well let's have a close look at what we have
Amlogic S905X Quad-core Cortex A53 CPU gives you a high-speed feedback and smooth response
2G RAM and 16G ROM, games and videos ran smoothly
2.4G WiFi and Bluetooth 4.0
Android 7.1
The Box
What in the box
Ports
Look Under
Off with the Lid
Pull out the Bits
PCB
Originally posted by trebor View Post[SIZE=14px][FONT=tahoma]Let's have a look at this a M96X MAX 4K HDR VP9 TV BOX Android 6.0 Amlogic S905X 2G/16G 802.11b/g/n LAN KODI Bluetooth
Android 7.1
I would try it out myself but my boxes got seized by customs, because in Thailand you need a tv box license to import a tv box these days.
Needless to say that such a license is near impossible to get.
Been a bit busy just flashed now as I found the installed a7 is not nice at all....
Sorry to read about your country's Licence rules....
More as it happens
Not not too bad at all, pretty smooth, looks a lot better with A6
Root, upper and lower
Same Ui as A7
Just have to wait till they get there act together with A7
Originally posted by trebor View PostBeen a bit busy just flashed now as I found the installed a7 is not nice at all....
More as it happens
Same Ui as A7
Trying to figure out the Z69 which get pretty over 80°C, hope not the same with this box
This is a strange Box I find, the Android 6 running in 720 viewport,
Temps in A7 fine nothing noted over the top, A6 did not test at this stage other things popped in.
As Mentioned all this needs is a decent A7 rom and should do well
The Following are Android 7
Android 6
As you can see they have upped the clock in Android7 and that would be why it was at a guess running a bit boggy
Originally posted by trebor View PostJust need an up todate Rom set right and should be fine,....\
Easy and Developer in the same sentence is the hard hard..
How do I make those visible?
Originally posted by Jancales View Post
I'm running Antutu on my Z69, but I don't get to the bottom screen shot that says benchmark and show the clock speed, nor do I get the 2 top screen shots with the dark background.
There are currently 1037 users online. 26 members and 1011 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
