Newbie question with droid box m5k5 Amlogic meson8b
Hi, i've just heard about Kodi dropping support for android versions below 5. My system has version 4.4.2 and CPU is ARMV7 processor with hardware Amlogic Meson8b. Only bought it just over a year ago, so now a bit miffed that I got to ditch it. Is there no way to update it for Kodi 17 to run?Tags: None
Meson8b... that's amlogic s805 if remember correctly
if yes
then you can try running libreelec 8
*libreelec 8 is a small Linux dedicated to run kodi 17 krypton (same as openelec)
You can probably run libreelec from sdcard without losing data/android... to see if it runs properly on your unit
see:
install/info
Cheers
Originally posted by mitchell4you View PostMeson8b... that's amlogic s805 if remember correctly
if yes
see:
install/info
Cheers
There are currently 2349 users online. 1 members and 2348 guests.
