SCISHION V99 - Hero RK3368 4/32GB Dual WiFi, Fast Lan, BT4
    Brand: scishion
    Model: V99 - hero
    Type: TV Box
    System: Android 5.1
    Processor: ARM Cortex A53
    CPU: RK3368
    Core: 1.5GHz,Octa Core
    GPU: PowerVR G6110
    RAM: 4G
    RAM Type: DDR3
    ROM: 32G
    Max. Extended Capacity: 32G
    TV Box Features: 5G WiFi
    Decoder Format: H.264,H.265,RealVideo8/9/10
    Video format: 4K x 2K,AVI,DAT,H.264,H.265,MKV,MOV,MP4,MPEG,MPG,RM,VC-1,WMV
    Audio format: AAC,DTS,MP3,OGG,RM,WMA
    Photo Format: JPEG,JPG,PNG
    Support 5.1 Surround Sound Output: Yes
    Support XBMC: Yes
    5G WiFi: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: DC Power Port,HDMI,RJ45,SPDIF,TF card,USB2.0
    Antenna: No
    Camera: Without
    Language: English,Germany,Japanese,Korean,Multi-language,Simplified Chinese
    Other Features: Suuport USB Camera
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Video
    External Subtitle Supported: Yes
    Power Comsumption: 10W
    RJ45 Port Speed: 100M
    System Bit: 64Bit
    WiFi Chip: AP6255
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Power Adapter Output: 5V 2A
    Product weight: 0.1350 kg
    Package weight: 0.5600 kg
    Product size (L x W x H): 13.90 x 11.00 x 3.00 cm / 5.47 x 4.33 x 1.18 inches
    Package size (L x W x H): 16.40 x 16.40 x 9.00 cm / 6.46 x 6.46 x 3.54 inches
    Package Contents: 1 x TV Box, 1 x Power Adapter, 1 x English User Manual, 1 x Remote Control, 1 x HDMI Cable
    Gearbest
    This Day we can have a closer look at the SCISHION V99 - Hero RK3368 4/32GB Dual WiFi, Fast Lan, BT4
    Bit of a blast from the past being a RK3368
    So lets get into it and start looking around
      Lets have a look at the V99 Hero Ui and some testing
      Running Android 5.1 bit of an oldy performance is OK, and with some creative luv could be a winner.
      WiFi Antenna was underneath on Base of Box moving it to lid has improved things in that area.
      Has a Standard Media box Launcher or and two others bit of fun if you like that sort of thing.
      Basics test as you will see are OK for its Vintage and may have potential to do more
      Most know the Pro's and Cons of the 3368 and reading around Freaktab will give you more ideas than i can ever test or show
        Android 6.0.1 already release for this tv box and better performance alot
          hi i have a problem with this box,can you help me,i wanna just know the reference of the condensator please
            Same Markings as other between usb ports.....
            It went BANG big time.
              thx bro i don't see it ahah new its good i see if i can buy one
                Condensateur électrolytique 100µF 25v 40 + 105
                  http://www.****.fr/itm/100-Pcs-100uF...EAAOSwaIRZuhDg
                  • trebor
                    trebor commented
                    Editing a comment
                    To easy hope all goes well.
                  The owners can confirm that this is a stable box, without lagging and freezing?
                    It would be much better to get a RK3328 instead.
                    The RK3368 is a very old chip from 2014 and it also looks like there is zero support from the manufacturer.
                    Also no 10-bit h264/h265 or VP9, so just look out for things like that.
                      Thank you mo123! What about the alfawise z28 pro?
                      Or are far better the boxes based on the s912?
                      I'm considering the Tanix TX92 and the Sunvell T95z plus...
                        pls help to find the android 6.0.1 for v99
                          Hi ,
                          look here :
                          http://freaktab.com/forum/tv-player-...-star-firmware
                          not sure what AndroidVersion it is and he says V99Star not Hero , same or different ??? dont know ,
                          you can try on your own risc / good luck / gefattern
                            hi all .
                            dump from V99 Hero , android 7.1.2 https://yadi.sk/d/94iqBQ99TzHkqw
                            712
                            • gefattern
                              gefattern commented
                              Editing a comment
                              Hi ,
                              a A7 for RK3368 , be happy / greetings / gefattern
