SCISHION V99 - Hero RK3368 4/32GB Dual WiFi, Fast Lan, BT4
Originally posted by Andro_James View PostAny ideas what will happen if I try to install it on my Beelink R68G for testing? Can it be the case that it will work fine? Or will it just kill my box?
is it a RK3368 Box , or not , does your Box use the same Wifichip ??? ,
but i am not sure this Box has 4GB of Ram , this is different , but maybe
a Dev. can say more ,
greetings / gefattern
hi all .
i'm built the custom kernel and spdif now work . so need people who test it. since I have no way to verify this.
the kernel and res https://yadi.sk/d/UAvUWl-AyoCmAA
ps
for gefattern
later share the firmware . im worked on src and right now i ported src to aosp NZH54D . im long worked on it , need makes some fix, than i thought.
and as said mo123 , not enough time .
good luck all .
There are currently 2044 users online. 1 members and 2043 guests.
