MXQ Pro 4k Bricked!! What pins to short for NAND.
Thanks scooter
Still the same
Starts, goes to 4% stays on saying "download Uboot" for 3 or so seconds then this error :12:08:33 085][HUB3-1][Err]--[0x10302001]Romcode/Switch status/Check connect/Enum device error
I have tried leaving nand short on while loading, taking it off when load starts, holding reset button on while loading , letting it go when it starts.
Also can u confirm that the pins i am shorting are correct. My chip has three large circles and one small one on the top. I assume i start counting pins from the small circle corner
This BOX is not going to BEAT me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LOL
Thanks for your insight....You give me a shimmer of light at end of tunnel
D
Youll find your not alone re OCD
Most comon locations there if you do find it post it for others following as i am sure you wont be last one looking for its location.
Keep at it youll get it.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Hello All!
People, can somebody help me. I have similar problem
My box is t95n s905x. In console i see this:
BL2 Built : 13:48:56, Sep 23 2016.
gxl g7459bd4 - jianxin.pan@droid06
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 1
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 528MHz - PASS
GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EM MC:0;READ:0;CHK:AA;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 228553
I see this message, when i trying to do something from micro sd port. Works only micro usb port, usb ports box don't see. When I trying to start box without microsd, in console I always see this:
GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EM MC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:1;EMMC:0;READ :0;CHK:AA;SD:800;USB:8;LOOP:2;EMMC:0;READ:0;CHK:AA ;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;CHK:AA;SD:800;U SB:8;LOOP:4;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP :5;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:6;EMMC:0 ;READ:0;CHK:AA;SD:800;USB:8;LOOP:7;EMMC:0;READ:0;C HK:AA;SD:800;USB:8;LOOP:8;EMMC:0;READ:0;CHK:AA;SD: 800;USB:8;LOOP:9;EMMC:0;READ:0;CHK:AA;SD:800;USB:8 ;LOOP:A;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:B;E MMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:C;EMMC:0;REA D:0;CHK:AA;SD:800;USB:8;LOOP;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:E;EMMC:0;R EAD:0;CHK:AA;SD:800;USB:8;LOOP:F;EMMC:0;READ:0;CHK :AA;SD:800;USB:8;LOOP:10;EMMC:0;READ:0;CHK:AA;SD:8 00;USB:8;LOOP:11;EMMC:0;READ:0;CHK:AA;SD:800;USB:8 ;LOOP:12;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:13 ;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:14;EMMC:0; READ:0;CHK:AA;SD:800;USB:8;LOOP:15;EMMC:0;READ:0;C HK:AA;SD:800;USB:8;LOOP:16;EMMC:0;READ:0;CHK:AA;SD :800;USB:8;LOOP:17;EMMC:0;READ:0;CHK:AA;SD:800;USB :8;LOOP:18;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP: 19;EMMC:0;READ:0;CHK:AA;SD:800;USB:8;LOOP:1A;EMMC: 0;READ:0;CHK:AA;SD:800;USB:8;LOOP:1B;EMMC:0;READ:0 ;CHK:AA;SD:800;USB:8;LOOP:1C;EMMC:0;READ:0;CHK:AA; SD:800;USB:8;LOOP:1D;EMMC:0;READ:0;CHK:AA;SD:800;U SB:8;L
In USB Burning Tool I have error on 2%, or 4%. Shorting 29-30 pins dont help, reset key dont work, and box after connecting to pc immediately enable loader mode without need to pressing or shorting something.This happened after the trying firmware 7 AndroidIf I understand, wrong firmware changes in my bootloader frequency of memory, and now box not start with this very high frequency
I know this thread is old but I faced the same problem and I have found out how to resolve it. Maybe it is still going to help someone.
Here is how you can recover MXQ_S905X V2_0 20161020. You will need to use aml usb burning tool.
1. Download rom from here
2. Short nand pins between 8 and 9
3. Connect tv box to pc and it should show up on aml usb burning tool
4. Flash firmware
There are currently 2993 users online. 0 members and 2993 guests.
