April RK3368 True Octacore Thread
Originally posted by Shomari View Post
no I do not feel rushed at all. Can you do me a favor and install terminal emulator and run 'getprop' and post the output here, please?
Had to jump through some hoops to get terminal emulator on the box. Google Play Store is one of the main reasons the current firmware is garbage. It force closes constantly. Even when you're not searching. Anyway, I got terminal emulator on the box and ran getprop. How do I copy the output to paste it here. Sorry for such a novice question, but I haven't used terminal emulator much.
getprop.txtOriginally posted by Shomari View Post
Originally posted by dkholm56 View Post[ATTACH]n643862[/ATTACH]
Shomari, Here is the result from getprop in terminal emulator. Not sure I did this correctly but it is in there.
Code:ro.bootmode: unknown
Try this system image:
Flash it, as usual, with the boot I sent you and hopefully we get some progress. . . vazarg I see you. We'll figure this out, guys.
Thanks! This is exactly what I suspected
ROM: 8GB NAND FLASH
https://mega.nz/#!jMBAXIBK!qodL1u8O-...-PHcmflCZX1EDs
flashed the boot you sent, and the new M8Pro System2 image over stock firmware. Box boots to M8Pro logo and no further. I'm gonna reflash stock firmware then your boot image. Make sure it boots then flash new system file and see if that makes a difference. Initially I flashed boot image and system image at same time.
thanks
Shomari,
thanks
Shomari,
thanks
I'll pm you the next steps from here.
well the second defect of the M8Pro is the faulty HDMI port. The connection to the board breaks away due to poor soldering. Already fixed it once by re-soldering the connections. I think it has broken away again because I have no signal when connected to HDMI but I do have a signal when connected to AV. I was concerned this might happen due to all the connecting and disconnecting of HDMI trying to test the firmware. Oh well, may check the HDMI port again may not. This box has been a PITA. What sucks is I have actually been careful when connecting or disconnecting the HDMI cable.
Originally posted by BEN001 View PostHi Shomari,
I'm using the firmware Z4_201703_4PDA with the kernel+resourse img from the firmware Z4 Android 6.0.1 (forum 4PDA),
TV box Z4 works fine- no overheating, shutdowns, power 5V 2A
May be you'll see and finalize this firmware with these images for Z4.
Duuuude sorry for the delay ... but family comes always 1st
But here is the shit I mixed up, with the help of your OC/T8C techniques ...
THX Shomari ... you are the manROM (Image/Firmware) for the Z4 RK3368 android TV Box (Andoer Z4 - ENY EKB368 - Acemax AK838 - Tronfy X6) stable . fast . clean . leanback . android TV (ATV)My contributions to the community
[ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
[ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
There are currently 2258 users online. 1 members and 2257 guests.
